172 cup RS2 - 330ci
Hehe so am I - I just borrowed a soldering iron, stripped half an inch of insulation from the switched 12v cable on the back of the ignition switch, stripped 2 inches of the end of the thin wire going to the EPAS - wrapped it around the bare part of the 12v cable, held the soldering iron under it until the whole thing heated up, fed some solder into it and then stuck some heat wrap over the whole lot. It's not the most professional finish in the world but a soldered joint is a lot more resilient to vibrations
I'll try your method instead. Did you use the same method for all the little wires? As on the others I've used these -
