Mondial 172 Cup OEM+ / Rolling Resto
OEM dust covers/bump stops fit fine on fronts. Rear dust covers not so much, on mine one has fallen to shock housing other stays up. Have asked two others who’ve had these, they didn’t have issues but personally would see if you can find a suitable aftermarket option before fitting. Haven’t had time to look myself yet but sure there’ll be an option that’ll fit and work appropriately.
Looking at your pictures again, you only get front shocks?
What springs are you going to use?
Thanks 👍
Yeah, front shocks only, I've got a set of GAZ adjustable dampers for the rear. Already running eibach sportlines on cup shocks at the minute so will be re-using the eibach springs
Got my new seat thanks to @Maccy for sending it on to me, it's a Driftworks branded Cobra imola, I don't love the DW branding but for £140 I can live with it Vs spending £640 on the cobra nogaro Ive had in my watchlist for ages.
I'll see how I get on with it at CSF, if I like it enough I might black the logos out with some fabric dye.
Also picked up a PMS shifter and a set of scruffy 182 wheels with AD08RS tyres on out of the classifieds.. I'll get the AD08's put on my turini's and probably move the 182 wheels on as I've no real use for them.
Really need to get my finger out and start fitting some parts but the landscapers have stuck a skip and two pallets of flags on the drive so I can't open the garage door 🙄
Done a little bit to the car today as the landscapers weren't around needing access to the skip.
It's done 1000 miles since the engine and box went in so I've dropped the gearbox oil and put some fresh millers crx oil back in it, took an age to fill it as the only clean hose I had was about 6mm ID
Then I dropped the engine oil and fitted the oil cooler
The hose is secured to the rad bracket with a cable tie for now, but I've ordered some 20mm P clips so I'll be able to secure it to a threaded hole in the alternator bracket when they arrive.
I'm pretty happy with how it looks, can't really see it behind the bumper other than the one AN fitting, I should have bought black but the red and blue ones were on clearance and I love a bargain.
I've gone back to a 5w-40 oil too, rather than the Total Quartz 10w-50 that was in it before, it had a little bit of lifter tick on cold start with the thicker stuff, and I don't think it'll need the thicker oil with the oil cooler stopping it from getting too hot. The tick has gone again with the Fuchs oil in it.
I also spotted a little coolant leak that I've nipped up on, it had lost a little bit since I filled the system initially, so I'd put a bit of UV dye in it a little while back and spotted it today with the black light.
I went to move the Clio off the drive this afternoon to plug the daily driver in and noticed a little patch of oil under the NSR wheel, thought it was brake fluid at first but had a look under it and the damper was covered in oil, strange as they were bone dry last time I looked which was only a couple of weeks ago. It's forecast heavy rain for the weekend so I made the most of the sunshine and swapped the knackered shocks for the Gaz adjustables I had serviced by Gaz a couple of months ago and some new powerflex top mounts.
I wanted to do the stub axle spacers and camber shims at the same time as swapping the rear shocks but haven't got time today.
The state of the rear beam makes me sad, I can't wait to get it off the car and powder coated this winter.
Things left to do before CSF:
1) fit bucket seat
2) get AD08'S fitted
3) rear stub axle spacers and camber shims
4) fit front Konis and alignment
Got the Konis fitted today
Arches are filthy from driving it in the rain to get the AD08's fitted earlier in the week, I'll get a few hours this afternoon to give it a proper clean.
I haven't driven it yet to see how much the alignment is out but I've had a lad at work 3d print a set of string alignment kit parts, just waiting on some Ali bar turning up so I can get it squared up before CSF
Looks nice and fresh, konis will be great all round.
Interested in the 3d printed string alignment kit, keep us updated.
Will this kit be able to buy?
I won't be selling it, I haven't got a printer (yet) and the lad that printed them for me is maxed out with his sideline of printing military trinkets.
That's the link to the free STL files I used, anyone with a printer can produce them, you'll just need to put the heating set inserts in, buy some thumb screws and some aluminium tube.
I'll happily give a materials shopping list for what I've used if anyone wants it
My aluminium arrived on Friday, so I've put the printed bits together and test fitted it
For anyone wanting to do the same you'll need:
2200mm 19mmx1.6mm round tube X2
800mm 19x19x1.6 square tube X2
600mm 19x19x1.6 square tube X8
280x280x3mm aluminium plate X4 (this is for the turning plates to go under the wheels)
A roll of anti slip deck tread (for the turn plates the tyres sit on
M6 thumb screws X16 (I got a bag of 20)
M6 heat set inserts X16 (I bought a cheap kit off Amazon)
M6X50 button head bolts X8
M6 nylock nuts X8
1mm paracord (I got a 50m reel for about £7)
I wanted to fit the bucket seat this weekend but another job took priority.
When I was fitting the oil cooler I noticed the bottom corners of the radiator looked a bit wet, not willing to risk a failed rad leaving me at the side of the road I ordered a Nissens replacement. It was on offer with euro car parts, £38 Vs the £100 or so PMS, Kam etc sell it for
I've also secured the oil cooler line to the alternator bracket, luckily I found this Rizoma bracket in the box of Ducati stuff, it was supposed to be a brake reservoir mount for a renthal handle bar, but it fit perfectly here, no more Pikey cable tie.
Got my seat fitted today, it's much lower which is nice, but despite the seat being as far over to the centre of the car as it can be the steering wheel feels more off centre than with the stock seat, looking at the stock seat it is offset on the base so it's just something I'll have to live with.
Fitted resistors to the seatbelt warning and pretensioner wires but I've got the SERV and airbag light on still, I only had 4.7ohm resistors in my electrical drawer so I've ordered some 3.3ohms for delivery tomorrow.. pretty sure I'll need CLIP to reset the warnings now though, anyone bringing a laptop with CLIP to CSF?
When resistance is correct srs/serv etc will extinguish, no need to clear. Need a different resistor, from memory 2.2ohms
I can reconfig the srs ecu with clip if needs be.
Car looks good!
What did you do for a buckle for the seatbelt? Got buckets for mine but keen to find a good solution, for the buckle and the correct resistors for the wiring?
I've used a Citroen C1 seatbelt buckle, depending on what seat/side mounts you've got you could re-use the OEM bucket and pretensioner
Theres a few threads on here that say 3.3 ohm is the right resistors to get
Cheers! Could you drop a photo of how you have it mounted please? Are all the resistance readings 3.3? For airbag and pretensioner
I had plans for a final weekend of CSF prep, fitting the stub axle spacers and rear camber shims, and checking the alignment.
Managed to pull my back (recurring problem) during the week but thought I'd be alright to crack on today. Got the car jacked up and one rear wheel off and tweaked my back again so very gingerly put the wheel back on, put everything away and have spend the day lying on my bed.
I'm not going to have time to do anything else now with being away at work Mon-Thurs so it'll be getting packed up with some tools and spares on Friday morning ready to drive down to Caldwell on Friday afternoon
Well that's not quite how I wanted my day to end, session one was slow with not knowing the track etc, session two felt a lot better but the front pads were smoking when I came in so sat out session three. Went out for session four and binned it on the second (I think) lap.
Still not totally sure what happened to be honest, it's obviously 100% attributable to driver error and I accept total responsibility. From memory the back end locked up and it instantly swapped ends, with me hitting the barrier NSR first.
I think the rear beam is bent as it looks like there's a bit of toe out on the NSR wheel, something is bent on the front too as there was loads of negative camber and toe in. The tie rod and bottom arm looks straight but I've had to wind the tie rod into the TRE about 10mm to straighten it up.
Disappointing but not the end of the world, thanks to everyone who came over to offer help and moral support, apologies to the people in my group who lost track time because I'm an idiot
I was only a car or something behind you when it happened and I was absolutely gutted mate. Main thing is you're ok and the damage doesn't look too bad. I didn't actually know it was you.
Nightmare! came out with not too much damage, defo need temporary ducting on track to the front brakes on these, what pads/fluid you running.
My cup brakes very lightly at the rear, yours should be the same providing it doesn't have the rod fitted to the compensator, luckily parts for these are cheap so not the end of the world
I've got Mintex racing MRM1801 pads and RBF600 fluid, I'm going to replace the front pads with some PBS ProRace and fit a new rear compensator.. along with all of the other bits that need replacing
Was a strange one as just at the end of the straight? Could have been a lot worse, what sort of speed were you doing when you hit the barrier ?
I don't know what speed I would have hit the barrier at TBH, can't have been that fast as it's not much damage.
Got home safely around 1400 which was nice, unpacked and made a start with the car
Gave it a quick wash and most of the paint from the barrier came off with some IPA, went over the scratches with some 1500 wet and dry and some heavy cut compound on a DA, it's far from perfect but it's much better.
Managed to knock some of the dent out of the quarter from behind with a nylon hammer too
Found this treat under the car too, a previous owner must have fitted it.. I really should have noticed this before but I suppose that's a contributing factor to the rear brakes locking up
I've removed it now 🙄
I've had the front up in the air too and I can't see anything obviously wrong, the bottom arms look straight, the tie rods are straight, camber is the same both sides. I've un-done the eye-lignment I did to get it home and it's steering straight-ish but the wheel is off. I'm going to book it in at a local place that does track car prep to get a second set of eyes on it before I start unloading the parts cannon at it.
Once I know it's not bent I'll get a couple of quotes for either getting the side of it repaired and painted, or bite the bullet for a full paint job over winter
That looks night and day better than it did after the collision mate!
I was genuinely gutted to see the damage on the car as well, but the main thing is, it’s all fixable stuff.
Has the rack moved slightly on its mounts?
I don't think so mate, I have checked it, everything is paint penned and it all still lines up and it's on powerflex black series rack bushes which are pretty much solid.
You may want to get the front braking checked to make sure its equal to both front calipers, a sticky front caliper over a few miles can also upset the front bias, all worth a check just to be sure
Slight kink on the strut where it mounts to the hub? Ive seen this happen on the r5's before, gives negative camber etc.
Looks straight by eye, I've had the camber bolt out to make sure it wasn't bent with them having a slim shank. I'm going to remove the damper and check the rod isn't bent next time I'm home, but with the car on the drive and a digital angle finder on the disc the camber is the same both sides.
I've sent AK automotive an email to get it booked in, they do loads of race/track car prep so will be able to get it squared up and see what, if anything is at fault. They did a really good job of setting my Nissan Laurel up years ago when that had all rose jointed adjustable arms
I’m gutted for you made. So much work has gone into it. It looked great when I saw it the other week.
That being said - main bit is you’re ok. Also the damage could be so much worse. As unlucky as it was to go off you’ve been lucky to pretty much get away with it
@MAXRUNDOWN I was gutted for you when you drove back in next to us in the paddock with the damage...
I'm really glad to hear that you managed to limp the car home and have already been making some good progress getting it all sorted. As others have said, it's all fixable and you were OK - that's the main thing mate.
Best of luck getting it all sorted and look forward to seeing you at the next one! :) (y)
