172 cambelt questions
Martin_172
  • Mot. 799-01 Tool for immobilising pinions for toothed timing belt
    Mot. 1054 Top dead centre pin​
    Mot. 1368 Tool for tightening the timing pulley​
    Mot. 1453 Engine support tool​
    Mot. 1487 Tool for fitting the inlet camshaft sealing plug​
    Mot. 1488 Tool for fitting the exhaust camshaft sealing plug​
    Mot. 1496 Tool for setting the camshafts​
    Mot. 1509 Tool for immobilising the camshaft and 1509 -01 pulleys​
    Mot. 1512 Tool for fitting the exhaust shafts seal​
    Mot. 1517 Tool for fitting the inlet camshaft seal​
Are all of these tools needed as i was under the impression it was only 3 or 4 tools? lol how much do all of the above cost if all needed? roughly​
doing my cambelt this month just want to make sure ive got everything to do it properly!​
ive got the renault workshop manual for it and it looks simple enough, ive done a few cambelts in my time just never one of these cars, im assuming as long as ive got the tools, and follow the guide properly for removal, refitting and tensioning, theres not really much that can go wrong?​
[*]Mot. 799-01 Tool for immobilising pinions for toothed timing belt
[*]Mot. 1054 Top dead centre pin
[*]Mot. 1368 Tool for tightening the timing pulley
[*]Mot. 1453 Engine support tool
[*]Mot. 1487 Tool for fitting the inlet camshaft sealing plug
[*]Mot. 1488 Tool for fitting the exhaust camshaft sealing plug
[*]Mot. 1496 Tool for setting the camshafts
[*]Mot. 1509 Tool for immobilising the camshaft and 1509 -01 pulleys
[*]Mot. 1512 Tool for fitting the exhaust shafts seal
[*]Mot. 1517 Tool for fitting the inlet camshaft seal
If you know what your doing regards cambelts yoiu'll be fine just remember to read it a few times.
The cam shaft seasl don't need the tool just knock them in with a hammer etc
The two tools you need are the TDC pin to hold the crank in place and the camshaft toll to hold the cams in place.
Can get them for £35 ish from motor parts places.
you NEED the look for holding the pulleys (MOT1509). If you dont use it you WILL turn the cam (and possibly break the locating slots as they're not strong) and throw the timing out
