172 f1 alloys on a ff 182
Car  renault clio 182
This properly a stupid question and school boy error but I'd rather ask advice looking at a set of oz f1's off a 172 that I've been offered is the offset and so on fine too put straight on my ff 182 or would I need spacers or anything?
Straight fit m8 I got mine on on the weekend , proper tight over the calipers tho if they're 15s
IIRC the 182s use the same front brake setup as the early 172s so you'll be ok. I have the F1s on my RB, admittedly they will look better if you have coilovers. I've also fitted 15mm spacers on the front to fill out the arch and 5mm on the rear
