chris blue
clio Sport 197
Just completed a gearbox oil change, and put some "STOP Leak" to stop the constant drips (Although looking at refurbing an 089 as diff bearings are f***ed on current one as well as the leaks)
Then decided to do an engine oil and filter change too, and removed fuel rail guard and connector just under it, to get at filter more easily (Jeeees they are a bugger to get off- took an hour of fiddling and cajoling)
On start up running very lumpy, realised i had not replaced the connector under the guard near the oil filter. What is that connector- a sensor os somekind?
Replaced connector, but still as bad. Sounds like a cylinder gone down, but decided to let it run a bit at idle to see if lumpiness cleared
After a minute or 2, noticed a pin hole leak in the pvc/rubber feed hose to the fuel rail- couple inches to the left, of the left hand side of the orange circle. (Pinched photo from another thread)
First- would a pin hole leak cause that much lumpiness? It was jetting out a couple inches. so assume pressure must drop a bit
Secondly- rather than replace the whole hose which looks a bugger to do, could i just seal the pinhole leak somehow? Heatshrink, or fuel proof tape of some sort. some other sealant Even is its just to see that the leak was the cause of the lumpiness.
Any advice appreciated
