May have a set of matched inlets to fit my the 172, only question is on the removal/refit of the lower manifold as the aux bracketry bolts into it in two places and while the bolts are removeable insitue from what I can see only the crossbrace to the block would be holding the alternator bracket.
The renault manual I have tells you to remove the aux belt obviously due to the bracket being unbolted for the most part, but is there another way to do it? as I don't really want to remove the aux belt due to them not supposed to be retensioned.
