Where is that Track???
Never seen the airfield layout before. Only ever known it as a rallycross track - brutal place that. Smells of rotting chickens if the wind is in the right direction.
That will be the maggot farm next door.
THE worst circuit i've ever been to!
Thats ace, what rallies are you planning in the future? I used to have a 205, nothing like that tho! Good old bog-standard 1.6. GTi power for the 205 Challenge!
What do they do to the trophy beams then? I'll show you what we've done when I get it back from the powder-coaters.
The bottom joints are the Race Car "uniball" bearings, in the special billet housings. I've got a few sets left if you want to try them, you will need a bearing holder, bearing, circlip, pin and the two bolts I think. You may need the Race Car bottom arms which are expensive and I've not got any of those left to sell. They're well different to the Clio std. arms though.
I had to shorten the pin by 16mm I think so that all the geometry came back when we raised the ride-height. Lots of technical hours spent trying to work out how to get around the problem of the pins being too long, and the bump steer having issues - easiest option was simply to shorten them!
I'll get some photos up when the car's out the garage again (hopefully this weekend when I refit the beam!)
Scott.
yeah rear beams are rubbish. the trophy has a few bits to make it stronger
hutchie
His car is Clubman spec group B like mine, so the rules are flexable regarding most things eg brakes, transmission, inlet manifold, etc etc. The only event he won't be able to do is rally GB Wales.can you still use the ex cup sadev box? or do you need to change it for group n?
lol the near miss was very close. was that a concreat bollard?
What pads are you going to run in the 4pots?
The engine bay looks mint. Any more biger pictures?
First practice event of this year will be at Anglesey Race Circuit on Feb 28th, and the first championship round will be at Weston Park near Telford on the 21st March if anyone would like to come and see the car in action!
Any comments welcome!
I Shall be there to watch, What time does it start?
Ace, il keep a eye out in our local paper will say on there hopefully, will do fella, if it has a big Scooty on the bonnet still then il spot you with no problem lol
Sounds good fella, il be around most probably as the track is only 20min from me, whats the chance of a free passenger ride![]()
