182 oil filter change
What a pain.
Can't seem to budge it. Just snapped a nylon strap wrench tying to remove it. It's made nonimpact apart from crushing it a little.
Also discovered 3 snapped bolts on the top part if the inlet manifold and also one of the bolts for the fuel rail guard is snapped.
Oh what fun :(
I did my oil on the 197 about 2 weeks ago. I had to buy a bigger pair of oil removal grips as the ones I had where too small! i ended up laying under the car pulling so hard the car was moving on the ramps!! one final tug and it came loose. theres about 10 inchs at the front of the 197 its not nice :(
2 tips for removing oil filters
1, borrow your mums marigold gloves, the rubber will give you 500% more turning grip if you can get ya hand on the filter
2, knock a screw driver into the filter and then use the handle on the screw driver to turn the filter, yhis is the messy option
both these methods will get the filter off
if 1, fails then 2, will def work
Either the grips or the screw driver option are the only things left I think. Trying to avoid the screw drivers as I have bad visions of ripping it to pieces and be left with the bottom bit still attached to the engine :(
Thanks guys. Anyone recommend any filter grips that I can get from motor factors or halfords/eurocarparts?
something like these. Mine are snap on, but you can get similar elsewhere
yup agree with this - as long as you stab it near the end of the filter no harm can be done
£12 from halfords.
Was looking at the renault fitment 76mm 12 flutes caps as I've used these on the replacement filter element style. Was think about getting one however since the filter had crushed a bit from the strap wrench I thought it might not be able to get a good grip.
Pliers are fab :)
