2, knock a screw driver into the filter and then use the handle on the screw driver to turn the filter, yhis is the messy option
	2 tips for removing oil filters
1, borrow your mums marigold gloves, the rubber will give you 500% more turning grip if you can get ya hand on the filter
both these methods will get the filter off
if 1, fails then 2, will def work
