182 rear quarter panel replacement - Part 2
Darren S
I can't believe that two years have passed since I had the offside rear done.
Regardless, the nearside panel and a replacement bonnet were ordered from France yesterday. :)
ETA will be 2 weeks minimum and the body shop is rammed until February at the earliest. Still, at least the wheels are now in motion.
I went through the body-shop who did the work last time. They contacted Renault directly over in France on my behalf.
I think this is the way to go as opposed to cutting and welding. what sort of ballpark are you looking at for the job on 1 side?
Matt Cup
  Leon Cupra, 172 Cup
Can you still get hold of window seals?
I‘m not after getting the panel replaced but I did notice my seals getting brittle and shrinking.
Darren S
As per @JamesBryan below - that was pretty much the figure I paid when I had the drivers side done. Quite a bit of fabrication for that too - so I'm hoping the nearside is a bit less labour intensive.
@Matt Cup - you can, but they are silly expensive for what they are. I checked (admittedly about twelve months ago) and I believe they were around £350. I assume that was for a pair - but it is Renault we're talking about here! I assume that all Mk2 Clio doors are the same - it might be worth seeing if there's one at a scrappers where the seals aren't in too bad a shape?
Matt Cup
  Leon Cupra, 172 Cup
Not doors fella. Rear quarter windows.
Like so.
MRBILLYUK
  FF Jeden Osiem Dwa
Like so.
That seal looks a bit strange. Has it had a new quarter glass in the past? It doesnt look like it's got the factory tint?
They are bonded in, but there's a seal inside as well.
Yours looks like it's coming out.
This is what mine looks like.
ex-Chinese Dave
Darren, so your window was put back in with the original seal still intact, right? If so, was there any issue with the seal?
Darren S
Got some money yow av!
It's a trade off mate.
The way I look at it, is that I've not had any form of car finance for well over 16 years. And while I don't bank what I would spend on finance as such, I do set aside a couple of hundred each month into what is effectively the 'Clio fund'.
So, when big hitters like this come around, or the cambelt being done several months back - I cringe like anyone else when I see the bill. But, I just take it out of that account. Makes it far easier a pill to swallow, that way! :)
