I'm no expert but I thought that would be more like the difference, from the lower pivot to the axis of the wheel.
Thinking back on it, elongating holes on a subframe is a stupid idea to be honest, especially with slicks and the forces there will be.
I will just get solid mounts made with same hole spacing as subframe but moves the rack up/down/in/out when correct ride height/ bump has been found.
You must have the same file as me, I thought you had tech spec's. Yeah your right, there's a brass type bush in hub to take standard Clio stuff or at least they fit nice, suspension has been fully together with old track rods and original wishbones, cup racer wishbones arrived now and new ends are on there way but I dont really know how to check bump steer
I understand the principal and what's required to adjust, remove spring and simulate droop/compression and measure it's affect on toe in/toe out... But I have no gauge and never used one, will need to invest.
Thinking on it Bump steer can only be setup with wheels parallel as when the steering knuckle moves the arcs of wishbone and steering arm differ, throwing it out, I guess it's just a balance.
