battery draining
  Laguna sport tourer
hello, my 182 keeps going flat im pretty sure the battery is ok. was wondering if anyone knows what sort of current it should be drawing from the battery with the car stopped i.e doors locked, interior light off and alarm disconnected i have clamp tested both the positive leads on the battery and they are both pulling 0.5 amps (1amp total)is this normal?
surely this would flatten a 47Ah battery in about 2 days
thanks James
  Evo 8 MR
Cold weather affects batterys.
If it's not holding it's charge its probably fubar'd.
A tell tale sign of this is the trip computer resetting itself randomly after starting the car.
jenic
Not normal.
I just had this problem and it turned out to be the alternator which was pulling the power. Wierd that both the car and engine +ive leads are pulling the same current, this suggests 2 problems rather than one.
Try using a multimetre in series on the -ive side of the battery and try with each of the +ive leads connected to test for draw. Then take it from there removing fuses/disconnecting the alternator etc.
  Laguna sport tourer
ive have a dc clamp meter at work gonna try putting that on and removing fuses one at a time but i suspect the alternator could be at fault or rectifier. also the old battery was load tested and scored 97% something like 500 amps
  Laguna sport tourer
ok so i fitted a new battery on monday (unipart 063 calcium) used the car for work on tuesday (50 mile round trip) went to unlock it this morning and totally dead managed to jump it to get it going and it was fine chagring at 14.4 volts. so it must be something drawing current when the car is switched off.
Any ideas?
  Polo + Micra
i guess that 1 amp over 48hours will drain a 47Ah.
i'd say you have something drawing too much current will the car is parked up
  Laguna sport tourer
yeah i guess so. im gonna stick a clamp meter on it tomorrow at wok and start pulling fuses. just wondered if anyone knew of something common that causes this fault ,as every fault ive had with the car has been a common fault lol
  Laguna sport tourer
ok it seems the alternater is drawing 0.6amps from the battery so a couple of questions
1. how much of a job is it to fit at home by someone with mechanical experience
2. can a new rectifier be brought or is a new alternator required (its a valeo one)
thanks james
  Laguna sport tourer
nope all standard, its defo the alternator when i disconnected the wire the current went to nearly 0 amps
jenic
new alternator time then, i got mine from the classifieds on here for about £50 i think, was only 9 months old :)
  Laguna sport tourer
well chuffed managed to fit new alternator myself so wasn't to expensive. just needed to remove front bumper and slam panel and clamp tensioner with a jubilee clip :)
