RSTuning
R35 GTR
Re: Ben_stevo172 - Supercharged Monaco 172
Yes is far too high if the gauge is reading correctly.
The fuelling dips to 10.7:1 in the midrange but indicated by the bosch sensor which isn't that accurate (they often read a bit richer).
It still needs to be checked over for sure. I might lean it out a little as the others have been fine running 11.7![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ben, the boost itself is a little high.... however I believe with the peak fueling (10.5?) you have, there is plenty fuel there. however I cant comment on the ign timing, so probably worth checking with Paul
