Is it cracked and you're missing a part or just a small hairline type thing? I'd try a fibreglass repair on the back of it as they do look so goodI made some when I owned it before and managed to do some without cutting the bumper but can’t remember how or what I used!!!!! I have a genuine splitter but it’s cracked so not sure what to do.
Not missing any bits just split in half.as you say might glue it back together then fibreglass on the rear and fill and sand the crack and paint satin black or even try wrap it.Is it cracked and you're missing a part or just a small hairline type thing? I'd try a fibreglass repair on the back of it as they do look so good
It seems to just be as strong as ever so I might have to do the same!I couldn't get to the bottom of my light cluster & fog light on the dash issue after I cleaned up all the connections. However a spray of WD40 on the loom connectors and also on the light connectors fixed it.
I did a buy. Sparco 300 suede wheel. Got it for a price that was too hard to pass up! Goodbye Bus wheel.
Finally.
I fancy the 383. Where did you buy yours?
Ooh, thought i'd seen it on someone elses car before but couldn't remember! Was it on your bg or ph1?Ooh nice!
I was going to message you with pics of my old Mono Team Black after you posted earlier on, but don't need too now!
https://www.oreca-store.eu/oreca-racing-suede-steering-wheel.htmlGot a link for the oreca
You don't know what I paid! Unless Daniel told you?Ooooooo fancccyyyy.
How'd you get it cheap? Second hand? Any more? If want one!
Looks good. What are the slits for?Mocked up a quick bracket in Solidworks. I'll tweak it more when the wheel arrives but you get the idea. Have to choose a button colour scheme next!
Allows the cables for the cruise control to pass through without getting squashed, same as on those FB ones. I'll be adding some engravings too but unsure whether to go for full words or just letters.Looks good. What are the slits for?
Had a knocking coming from my front end so I went over all the engine and gearbox mounts and retorqued them and loctited them as I believe it was the manifold banging on the subframe.
I also managed to get this fitted!
I have cruise control bracket to finish wiring up and also some airbag resistors to get but I'm chuffed with how it looks.
Can't wait to drive it!
Finally no shocking looking grille[emoji57][emoji6][emoji23][emoji23]
Did ya not do moments at school?
"Moments. A moment is the turning effect of a force around a fixed point called a pivot. For example, this could be a door opening around a fixed hinge or a spanner turning around a fixed nut. The size of a moment depends on two factors: ... the perpendicular distance from the pivot to the line of action of the force."
So yeah, normal that you new wheel.makes you feel weak[emoji23]
I have my moments[emoji23]Glad you remembered that from your school days all those years ago Paul
Paul used an abacus in school so take from that what you will
