Carpet / underlay replacement
  Clio 1.2 16V
Hi all
I had a really bad leak which has now (hopefully) been fixed. The foam underlay in the whole car is absolutely ruined and is just unsavable. I have managed to remove most of it but having some difficulties with the front footwells.
I cant seem to get the carpet up , it seems to be tacked down good via the sides somehow and I was wondering if anyone had removed it before and had any hints or tips and/or if i am missing something?
Any help would be greatly appreciated, the plan is remove and refit new foam / carpet.
  Clio 1.2 16V
Ok so I ordered the new foam & carpet and just took a stanley blade to the current one. I now have managed to get all the foam out and binned and new one should come on Monday.
What I noticed though is that there was polystyrene and a black plastic moulding type thing under there too. So the question is will it be ok to just put the foam and carpet down or shall I try source the polystyrene and moulding too?
JP83
South Central-Oxfordshire
Where abouts Claire? You need to be careful of things like the pedal box in the driver's footwell.
I think the foam goes a fair way up behind the dash from memory (I should know as I stripped mine out), but can't be 100% sure.
Did you find where the leak was from? Blocked scuttle drains are the usual culprit. There's 3 of them -1 each side and 1 in the middle of the scuttle panel.
