Coilovers
Car  Clio Campus 1.2 8v
Hi, I've recently bought a 1.2 8v Clio Campus (57 plate) and would like to add coilovers for a 50-60mm drop. Im not to sure on which ones would fit as I've been told various types would and wouldnt fit. Thanks in advance, great forum!
Morning Graham,
Can't help you with any suggestions, but a lot of people have had the same question over the history of ClioSport. If you dont get many helpful replies on here, have a search.
As long as you dont get "sport" or "cup" parts, they should go on your hatch no problems
@TheTomB96 Chances are he won't remember if he does reply, the original post is over 2 years old!
Your best bet would be to get under the car with a measuring stick and measure the distance between the centre of the bolt holes in the front hubs.
At a guess, I'd say the Campus was based on a facelifted mk2, so chances are it uses mk2 suspension.
The standard mk2 uses a 58mm bolt spacing, if this is the case for yours, there's some fairly cheap coilies on ebay for it.
