Colombo&Bariani`ed Clio RS
Car  RSTUNER'ED-C&B'ED RS-1
old one`s out new one's in :)
Colombo Bariani cams
Camshaft details
Part No. R2R.SM1
Make Renault
Model CLIO 2000 RS
Model with phase variator
Camshafts codes R2R.057.286S (1)
R2R.055.280S (1)
Application Road medium
Cam lift IN 5.7
Cam lift EX 5.5
Duration 286°/280°
Timing 19°-87° / 70°-30°
Timing with phase variator opened 39°-52° / 70°-30°
Lobe center angles 124°
Lobe center angles with phase variator opened 104°/ °
Valve lift TDC 0.5 / 1.2
Valve lift TDC with phase variator opened 3.5 / 1.2
Clearance Hydraulic tappets
Colombo`s arrived
standart one`s out
Colombo's in
cam timing
very very stable idling. still very good low down torque.
awesome power and sound
haven't got a chance getting it RR'd but will do it very soon.
Did you re shim the engine? do you need to with these engines? couse i had to with my old fezzy and it was a pain in the penis to get it sounding ok and not rattley as fooooook
No need for re-shimming. Even you do not have any other option. Top cover is all in one-piece.
so who have these been made by? a lolly pop eating baldy?
renault dealer installed it. Cams are from Italy, please keep your sense of humor to you. If you want to know details of the installation just ask.
hey just lightening the mood not trying to cause any offense if i did a mod can remove the post, other then that good work!
no offense m8 sorry,
just wanted to share what I did with you. But when you see something criticizing your grammar only then boom you are out of control. This is my 2nd probably 3rd language so sorry about my bad spelling and etc. I will be more than happy to explain the details of the cams and etc.
Best
Did they take long to time in after fitting? did you change the pullies ? do you still get 5k kick or is it now more progressive through the revs ?
Std timing tools are enough for this purpose. Yes it takes a little time to lock it in its position.
No need to change the cam pullies since this cam is not that wild. If you do, then you will loose VVT so pulley change is pointless unless you have racing one's. Have not hit above 5k rpms yet. The crank pulley on the car was f***ed. Ordered the new one. Waiting for getting it installed. I will not push the car so hard in the mean time. The cam profile is very much like Schricks.
will you get any gains from those cams ?
car gave 150.7 HP ATW before the cam installation. I posted RR graphs before on this forum. Around + 15 HP gains are expected but without RR plot there is no point for discussion.
You will Have to post up whats its like & power it makes once you have it all sorted & run in for a few miles.
Let us know how it goes once you got it all setup and working, will be interested to know...
Clio Cup crankshaft pulley has just arrived, saturday it will all be ready. Cannot promise for the dyno sheet immediately but will shoot a speedo video.
the weird thing is you guys in UK are not familiar with Colombo Bariani's. Though you know Schrick's very well, kind of marketing strategy I think. Colombo has a very good name in Europe.
