Cup Spoiler question
  PH2 172
Gonna have a bash at fitting mine although ive just read a post that said the connections for the brake light are different and the hose for the washer jet is too small?
is that the case when fitting a cup spoiler to a non sport or will i have the same problem fitting it to my 172? cheers
My connections were the same which made it easier but yes they maybe different.
The hose was a bit short on mine and was a royal pain to sort out, I took an extension to the hose off the old boot.
I would recommend you get a friend to help you, its tricky to attach by yourself because you have to hold the spoiler in place.
Finally this may sound silly but there is meant to be a small gap between the underside of the spoiler and the glass, I made the mistake of fitting my flush to the glass and the boot would not open properly, hope that helps.
Hope that helps.
  330Ci (Fail)Sport
Same as Rob said for me.
Mine came with the correct attachement for the brake light as well.
For the washer hose, mine was too short also but it doesn't work anyway so I didn't bother sorting it out.
