Hi,
I'm having a bit of trouble fixing an abs fault on my clio, tried diagnostics (4 different machines, 2 being renault clips) and none can seem to access the ABS ECU to obtain any fault codes.
I have tried having the ABS unit replaced (Pump+ECU unit), and had it back on the diagnostics but the machines can still not access the ABS ECU.
I was advised by the garage that it could well be damaged cabling in the loom somewhere? After much research I found a common problem was the "Black Box" connector on top of the ECU. After (painfully) removing the metal box, and the glue stuff I noticed some of the wires have been chaffed through. I have had these fixed up and covered, along with padding the box and leaving the cover off to prevent any more damage.
This did not however solve the ABS issue, and after yet another trip to the garage they suggested to try a continuity test on the plug going into the ABS ECU to the plugs on the other end of the looms. However, I'm struggling to work out where all the pins out of the ABS unit lead to.
Does anyone have a wiring diagram or any pin out diagrams for the D4F engine for the ABS and ECU systems. I'm particularly after anything that will help with tracing where a possible broken wire or damaged connector/plug could be.
Thanks,
Gary.
Thanks,
Gary.
