clio 182
Very nice, sorry to hijack your thread btw. Also strange how your log manifold has circular exhaust ports?
I'm redoing my cam timing tommorow, ill lock crank at TDC, loosen inlet pulley and manually rotate the cam until the piston hits the valve and upload a picture to show what angle this is and show you the sort of cam timing angle that is required.
don't forget 5 degrees at the cam will only be 2,5 degrees on the crank. don't know if you did it to decrease overlap or just so it doesn't hit the piston?
AndyRG said he used his fixed timing on his meggane turbo 8 degrees permanent advance to get his 326bhp which contradcits exactly what is discussed above about reduced overlap helping, which is quite strange.
But from what i can make out the timing change i have done will reduce my low end a bit (hitting a max of about 5-7 degrees advance compared to the stock 16), but will beneficial on boost and higher up. But like we all know, the proof will be in the pudding.
How does it contradict what is above?
His EGT's would be higher doing that than if he hadnt, but that doesnt mean it wont still work, and there are other ways to help control EGT anyway, like design of manifold and how rich you run the engine.
if it doesn't differ that much you maybe could work the manifold to suit your ports better?
Chip, wouldn't advancing the exhaust cam eat up more of the burning process since the valves open earlier in the cycle? so maybe better spool but less topend although because of less overlap it would still benefit over the whole upper rev range.
could be a good mix 'n match to get most spool ánd most power in revs. you f4r guys are lucky you won't need verniers, saves another 250 quid! although which isn't alot of money for the gains that may be had!
don't forget as you've seen in the chart the timing of the megane is different from the start, so maybe advancing his inlet cam on the Megane standard timing would still be retarded compared to the F4r standard timing. i don't know what turbo he used but if he used a larger unit that the original one for instance it would benefit from having more overlap as the turbine would suffer less from backpressure. i hope this makes sense to you![]()
won't that result in slip of the pulley? if not then yes, that would be a good solution![]()
Agreed, an interesting topic thats not really talked about much none the less.
9:1 CR, further stock f7r with standard cams and timing, 95ron. tuned by scoff to 320bhp
i'm not sure mate, think it has adaptronic and wasted sparc coil. but there could be an other issue i don't know about....
does 95 opposed to 97 make that much difference? i wanted my 9 mapped on 95 aswell as there are getting less and less pumps out here selling 97.
difference here is more like 15 cents a liter. not that i care about that but if i'm not able to fill it up with good premium fuel it would s
*ck bigtime when i want to floor it!
With mega squirt its all about who built it. James Murray is who I would recommend to get it from over here. I know him quite well so if you say I sent you he will have plenty of time for helping you out I'm sure.![]()
So which is best for running my car the omex or mega squirt? Cheers
Both will do it. Omex is better supported by mappers, mega squirt has far more sophisticated fuelling algorythm and far better boost control. Quite a tough call tbh, I would ask whoever will be mapping it for you which they prefer. Scoff for example loves adaptronic and that's also very capable.
