Detailing Chat & Questions Thread
I'm gonna use some hydro2 for winter protection on the daily I think. Is the Lite stuff enough for this or would I be better going for the undiluted stuff to get it a bit stronger?
Lite is fine mate. Lasts for ages.
And it also has more silica in it for that dilution ratio than if you were to dilute the normal stuff.
I'll be ordering some more and think I'll just get Lite next time although I have loads of distilled water left it just seems more convenient.
Another question - Single stage polish and pad combo, Talk to me.
CarPro Essence?
Look at Wolfs Nano glaze too. I think they are more fillers with a seal rather than polish though
CarPro Essence?
I still love Prima Amigo but it doesn't have much cut.
What about CarPro Fixer?
Their website talks a good game but is it all they say it is?
I've got the likes of AF Tripple, AF Ultra Glaze, 50 Cal Cover Up and Menzerna 2500/4000, Just hoping I can get something with more cut than Tripple but but that won't need refining after using it for those 1 day turnaround cars.
Have you seen the cut with a gloss pad from Essence, killing 2 birds with one stone.
Even essence plus gets some bite from the pad and nicer beading.
@Coby. You can't go wrong with carpro essence, especially if you can apply it by machine. If fills, it corrects as much if not fractionally more than a finishing polish. Tyre finish is so deep and rich, and so slick. It really does leap ahead of the usual AIO's and pre wax cleansers and glazes.
I used it today by hand and it was still so easy to use and remove.
You used it or seen it used Kev? I'm sure I'll get a bottle when released but not sure if I'll really have much use for it. Carpro Essence topped with waxaddict quartz used today is a lovely finish. And previously proved to be a resilient combo.
If you have essence not sure you'll need it that much unless you're a pro.
Have you done any 50/50 by hand?
I don't have it yet. Out soon though! They posted over on DW a video of it.
I think it's more of an LSP like a DA applied sealant but modern. It's what I've been desperate for for years. The others are shat.
The beading and LSP characteristics of plus I think will attract some that aren't looking to correct just seal. Also not in need of reload over it like non plus.
I ordered some essence yesterday.
This morning I used a sample bottle of Reset shampoo on the work car because we'd run out of the generic s**t that the job buys. I was really impressed with it. Think I'll be buying a large bottle of it.
People still rate stuff from Auto Finesse?
Just took advantage of their BF deals.
Bought;
Drying Towel
Tripple (needed)
Iron Out
Avalanche
Free;
Wash mitt (needed)
Glisten
Imperial
Citrus Power (wanted)
Yeah I've still got plenty of their stuff in my kit, May not be the best out there but it's not overly fussy in application etc so I'm happy with most of it.
I mainly use Auto Finesse. I'm very happy with the results I get from the range. I wouldn't be part of the network if I didn't believe in them :)
The only product I don't keep in stock is Citrus Power. Everything else does exactly what I want it to.
Super Resin Polish is still a good product. The newer formula is just as good. The dusty complaints were usually from people using way too much.
Good to know, I have some other bits and all works, just didn't know if it was a good good product.
What would you use instead of citrus power?
So I want to give the new TT some protection over winter.
The ambient temperature tomorrow will be circa 7c - is this too cold / inflict holgrams? Would I be better with a spray on LSP like Somax BSD or CarPro H2O?
Essence is slowly getting used more and more, it's replaced my finishing polish and glazes by hand and machine application. Performs and applies so well. Never let it's durability run it's course fully so can't comment on that.
Reset shampoo is another good product and have plenty of it. I know it's primarily meant for coatings but have used it on generic waxes at about 400:1 and it's been ok
I've not got a pressure washer [emoji23]
That's fine. You don't need to use one.
A garden pump sprayer to get a spread of the pre wash on the car, then rinse down after a few minutes with a hose. You'll still pull some surface dirt away.
You'll be fine to apply your wax.
Just try and do it earlier on before the dew point sets in. You might need to leave the wax a little longer before removing. The cold can slow down the cure time.
You ever checked correction by hand Dave? Also, what applicator?
Tri foam applicator. Tend to initially worn it with the firmer white side before going back over it later with the softer black side.
Never followed it up with a wipe down to check true correction but it certainly fills pretty well.
Have you ever tried essence by machine on any firmer pads? So far I've mainly stuck to the carpro white gloss pads or similar but curious to know how well it'll finish with a more aggressive pad
Brushes - Talk to me.
I have my Wheel Woolies and AF Hog Hair brushes but my cheaper selection are all falling to bits.
Don't want to spend a fortune but need a few for Wheel faces, working around badges etc.
The Envy brushes always seemed to be highly regarded and I've had mine for years and they're still soldiering on. Not sure if there's any better ones about now for similar price.
I always used the generic envy style or the black valet pro brushes. Then I got the autobrites dbs brush set and not used anything since. Didn't buy them direct though I can't remember who stocked them.
http://www.autobritedirect.co.uk/index.php/the-dbs-detailing-brush-set-by-autobrite-direct.html
My envy brushes haven't moved from the shelf recently. A mix of Wheel Woolies and my slide lock brush is all I tend to need, fella.
Got my CarPro order in the other day
Free bottle of immolube, free delivery, and 10% off it all. Excellent service!
Is Trix any good? I bought it as the lazy option to help with decon before I put some hydro2 on over winter.
Nice haul.
Usual thing with "All In Ones" - they're not as good as dedicated products. Tardis and IronX remain the best.
