1.6 Astra Sporthatch
Can I buy them online as there isn't a Costco near me ?
I use Kent car care ones from Asda, around £2 for 6 iirc
As above, the company is eurow, not too badly priced tbh.
What's every ones favourite shampoo?
That's a brilliant transformation. I imagine that was very rewarding!
What's pads and polishes did you use?
on a side note anyone thinking about upgrading a das6 to the pro version get it done, very impressed with the machine
Even more reason to do so with the DW discount too.
Great outcome from your work!! Very impressive result. How quickly could you see the result of each step?
Mate of mine has spots of creosote over his car. He's taken it to the usual 'car wash' place who says they'd get irbid but it's still on there. He's asked me how to get it off. I'm thinking decontamination with an iron x type product, tar x and then claying?
Reckon that would shift it all?
So, my second most hated colour of cars. White.
My preference would be Tripple and Tough Coat for a glossy yet durable finish. Anyone have a better combo? I want it looking wet, and to stay like that for a bit.
Just got a Das-6 Pro with AF kit from a member off here. Gonna be needing some advice.
Is the AF kit good? How do I go about cleaning pads after use? Should I look at getting some new pads, if so which ones?
Thanks.
From my experience with #2 polish and pad the other day I'm impressed. Didn't need #3 surprisingly. It's very, very dusty when used outside in the sun though.
I washed mine with warm water and left to air dry after being advised to do so by AF at FCS.
Cleaning has been neglected by me for some time, so I need to do a full job, I've used Iron X, Bilt Hamber soft clay, etc, so I'll be sticking to that stuff for the decontamination, it's just the polishing and finishing, even more so now using a DA that I have no experience with.
Use some tar remover in between ironx and clay. It'll make the clay inflict less marring and make polishing/finishing easier.
what DA is it? My £5 wonder (unbranded megs g220) has a sort of clutch that kicks in if you apply too much pressure so it stops spinning.
FG 400 is great. Always finish work something lighter though
I know this has most likely been asked before but trim gel? My front grill is looking rather grey. I bought some Chemical Guys trim gel a while back, applied it thinly just to test and as soon as it rained it ran down the car
Auto finesse revive is decent from my experience.
Turtle wax tyre and trim gel smells awesome. I buy it just for that tbh
I use chem guys trim gel and its better if u buff off and apply 2nd time then buff lightly but yes if it rains not long after u apply it can run i just QD it off then happy days!!!I know this has most likely been asked before but trim gel? My front grill is looking rather grey. I bought some Chemical Guys trim gel a while back, applied it thinly just to test and as soon as it rained it ran down the car
So, first time I've used the Meguairs Microfibre DA system.....only used the cutting pads and compound so far. Wholr it's achieved I'd say around 70% correction - it's also inficted awful hologram / marring streaks over all the paint?
Only used in the shade first thing before temps rise - pads were fully primed then spurred after each pass?
Hoping the LC tangerine pads and Megs 205 will rid the defects
it sounds like you've not cut your own marring out, read the stickies at the top of this section.
when you cut the original defects out by working up to a speed, you inflict your own marring, which is the holograms... Come back down to a lower speed to cut these out.
Sounds like a lack of proper MF cleaning also.
I'll give it a go - however, reading on Meguiars own site and also Polished Bliss, you don't work the same with as with foam pads - speed 1 to spread paint then straight up to speed 4 / 5 for a few passes - done.
Never had this problem before on my previous black cars!
