A solvent based wax like colli or fk are likely to interefere with any base product. And ideally should be applied to bare clean paint for maximum results and durability. You can use them over something like tripple or SRP but be aware that you will more than likely find it dies off sooner than normal so will just need to re apply sooner.
Tough coat is a non nano sealant. Can be used over tripple, but again works at it's best off clean paint, but it's as easy to use as a quick detailer re applying once a week would only add another 5-10 minutes to a wash
Tough prep is a chemical cleanser, with minimal if any abrasives. It's designed to deep clean the paint more than just normal decontamination and washing, leaving behind a great base for applying sealants, of which colli and fk strictly are. Just because they come in a paste wax form doesn't change that.
My advise, drink the reload and get the nano system in you sooner rather than later then you can use it on the car. Far worse being out into our air and water ways
You are a gent, sir :up: - that has made things a little clearer, although like many a good Indian restaurant menu, making a final choice when so many are available and attractive is difficult...
It sounds like the cleaning/prep part is the easiest to decide - the following looks to cover all bases and bring the paint to its cleanest and ready for polishing, going from what has been said, so I'll definitely get these unless anyone tells me I'm an idiot:
CarPro Tar-X
CarPro Iron-X
Auto Finesse Tough Prep
Bilt Hamber Clay (regular)
After that, a plethora of options seems to exist - tell me if this summary of what everyone has kindly tried to help me understand :up: is utterly wrong...
Polish -
used first to remove scratches / restore colour (but ideally needs to be cleaned/stripped afterwards with Tough Prep or similar if wax or sealant is the next step?)
Solvent-based Wax -
should be used straight onto bare paint
'Pure' Carnauba Wax -
can be used straight on top of bare paint or polish or sealant as is non-reactive (?)
Sealant (non-nano-tech) -
may interact with ingredients of polishes and waxes so should be used on bare paint
Sealant (nano-tech) -
inorganic so can go on top of anything, whether polish, wax or bare paint
So, if I have this in any way correct, the decision to be made seems to be whether to go:
Polish > Carnauba Wax
or
Polish > Carnauba Wax > Sealant (nano)
or
Polish > Clean/Strip (e.g. Tough Prep) > Solvent-based Wax
or
Polish > Clean/Strip (e.g. Tough Prep) > Solvent-based Wax > Sealant (nano)
or
Polish > Clean/Strip (e.g. Tough Prep) > Sealant (nano/non-nano)
or
Polish > Clean/Strip (e.g. Tough Prep) > Sealant (nano/non-nano) > Carnauba Wax
Is that right?? Am I a blind/deaf muppet who can't read or take anything in?? :dizzy:
I really don't know what's happened to me in the 5 years I've not really been around on the forum, I swear it was a lot easier when all we had to do was walk into Halfords and pick up the AutoGlym selection box, then wash, clay, slap on some Super Resin Polish and top off with some Extra Gloss Protection... 😊
[/old man]
