Engine Mounts
Car  www.renparts.co.uk
Just to confirm. mk2 ph2 1.4 16v there are the following mounts.
Top engine mount on drivers side visible from under bonnet.
Dogbone mount where the engine is attached to subframe under the car
The mount under the battery,
are there anymore?
edde said:
There one betwen the gearbox and the subframe.
nice one edde i was hoping you might say that, where can i locate this and how much is a new one and how easy is it to replace?
No idea on price probably £40 or so.
Won't be difficult to change.
your car dont have the one between the gearbox and subframe josh, you can how ever retro fit it
the front plate bolts onto the front of the gearbox and the rubber mount attached through a hole in the subframe (you need to make a hole) i wouldnt bother on a 1.4 too much effort. the k-tec dog bone mount will give you less movement.
whats wrong with your set up at the moment?
