Engine sensors. DTA S60 wiring
RuskiWeldFab
  Clio 172, RS4 B7
Hi lads. Started on the loom today. Quick question, are the sensors one sides or not? Most have 2 wires like air temp, water temp, oil temp etc. They have a 5v/12v feed and signal to ecu. Does it mater what pin goes to what like and LED bulb? Or like a normal light bulb?
RuskiWeldFab
  Clio 172, RS4 B7
Actualy most have ground and signal. 5v/12v only 3 wore sensors like TPS, MAP, oil pressure
  406 V6, Race Buggy
Air temp, water temp, etc, 2 pin sensors are usually just sensor earth to one side and signal the other pin, doesn't matter which way around for most of them as they're just resistors.
RuskiWeldFab
  Clio 172, RS4 B7
That’s what I figured. Thanks buddy.
