Fitting 182 driveshafts/hubs onto a 172?
Car  02 Iceberg 172
Does anyone know if it is possible to fit 182 driveshafts and hubs onto a Ph2 172?
I know 182 driveshafts won't fit onto a 172 due to the driveshaft cv/hub end being different (location of abs ring etc), but if you were to fit 182 hubs then the 182 driveshafts should fit yes?
I assume the 182 hubs will fit ok as iirc the wishbones aren't different between the 172/182 (apart from a bit of castor), or are there issues with the ABS? (location of the abs sensor, number of teeth on the abs ring etc)
Appreciate any feedback :)
