Fletch's 150k 172 Project..
Fletcher
Quick update:
Dropped the car off a Rentech to get the ktec stealth removed, and a PMS exhaust fitted, cheers @Mike@Rentech :smile:
Untitled by Fletcher Cox, on Flickr
Only done about 60 miles with it fitted so far, but am very impressed it sounds great, very raspy!
And these arrived yesterday morning. Chris Powell 280mm Brembo brackets.
Currently running standard calipers, Brembo HC discs, Goodridge lines/ ATE super blue and and CL RC6 pads, so don't really have any need for another set of 4 pots, but like the weight saving, and being able to run a less aggresive pad (to stop ruining wheels etc)
...Hopefully give it a good clean over the weekend, and get some go pro footage of the exhaust.
Fletcher
You reckon there's much in it with the weight saving? Especially if you go for bigger discs with the Brembos..
If I do go down the Brembo 4 pot route Martin I will run standard Brembo HC 280mm discs, to get under my 15" wheels.
My old Compbrake B4 4 pot kit with separate bells was much much lighter than the standard calipers/ OEM Renault set up.
Ex-User (72296)
  Clio 172
Saw this again at Rentech on Monday, cool as always.
Mike was saying a few expletives about some of your exhaust bolts I think haha!
Fletcher
Christopher.
South Central-South Coast
Mine is very tinny. Sounds epic in goodwood tunnel.
Il actually be around next weekend so we can go for a blast then. Will be on the standard wheels then as well.
