Fletch's 150k 172 Project..
maynard
  ph2 172 track car
How did you get on with the glue?
Most definatly get rid of the light unit, I have. Just got the wires running up the a pillar and across the roof to the windowscreen now.
Fletcher
I've not tried to remove the glue yet mate.
Good idea that. The light unit does look very clumsy now the headlining has gone.
Fletcher
Me and Tim adjusted the seat yesterday, as I was sat far to close the pedals/steering wheel Much better seating position now :)
Fletcher
Fletcher
Update.
Last weekend Tim gave my headlights a going over with the PC polisher. They look much better.
And I have now removed the front door cards..
Since this pic was taken, I have removed the plastic honeycomb stuff in the door lining, and given it a bit of clean :eek:
Thinking about some CF door cards eventually, and removal of the front speakers, and HU.
Roll cage first though :)
daveski
Done the same with mine today. I have tried to hide the wires in the door skin to tidy it up a bit, got to sort a mounting place for the window and mirror switches now.
  182 trackday racer
Nice work fletch. Keeping about the same build pace as it seems.
Im building a custom cage at the moment and Oreca GF door cards on their way
Fletcher
Plans sound good mate. I am looking into roll cages ATM :cool:
Polycarbs and CF door cards are what you want!
Yes mate, I want to tidy the door cards up, some CF cards would fit the bill nicely, and the polycarbs would save some more weight :approve:
maynard
  ph2 172 track car
That will be next lot of purchases after some more wheels/tyres!
  182 trackday racer
IMO that cage is not a very good cage, read the FIA regulations an you'll understand why. No low horizontal bar connecting the "legs" in the mainbow + the connections in between the front bow and main are not allowed in that position. Same goes for the diagnonal over the front window.
Strictly my opinion but that is a styling cage nothing else. Not sure if it will be any good if you'll crash. FIA saftey regulations are restrictive for a reason.
With a few extra bars and other connections it could be a much better cage.
Fletch for the money you'll spend buying it and modifying it to fit, you may as well get a custom cage like I am. It'll be fia approved, have more cage to it as well as being better structural wise (pick up point on rear shocks and b pillar gussets). And above all else it'll be lighter than the caged one and uses better grade materials using 'cds'.
Really depends though on whether you'd want to take it out and sell once you've finished with the car.
Give me a pm if you want to know a bit more! :)
  Evo 5 RS
Depends how far you want to go, the OMP cage is FIA approved and isn't Three Thousand Pounds.
but on the other hand, Caged will be able to alter it to meet the standard if you so wished, only have to call
  Mk2 Escort
Loved this last night, sounded the nuts. Surprised security didnt come along.
I forgot to give your seat a go though mate. Ill have to try it at FCS for sure. If you want your headlights going over with a rotary give me a buzz and ill give them a quick go over.
Fletcher
Yeah guys you do have a point. The car will never go back to standard, and doesn't have much left in the way of interior, so I might as well go get a 'full' on roll cage.
I do still like Neil's roll cage mind.
Isn't the OMP a b**ch to fit?
Cheers Sam.
Yeah you're more than welcome to have a sit in the old girl. Great seat the old Corbeau revolution :cool:
Giving the headlight a going over with the rotary sounds good mate; Cheers.
Fletcher
I bought a RS tuner a few weeks back, and finally installed the overrun map...
Hopefully get a some better videos at the weekend.
Fletcher
Started the car up yesterday, and noticed the STOP and Battery light icon are now on :(
http://www.cliosport.net/forum/showthread.php?579103-STOP-SERV-amp-Battery-light-on.&highlight=
The car still drives and pulls as well as ever though, and I had the Alternator/aux belt and battery changed in January, so hopefully nothing serious or expensive to fix!
This morning I gave my tow eye some TLC with the dremel it looks a lot better :approve: I am still really liking the overrun map, MPG has dropped a bit though currently reading 28.8 :eek:
Yes! The 2 OMP ones I had were poor, and I mean very poor that would of needed a lot of 'work' to make them fit!
When speaking to Mike at Edwards Motorsport (the person doing mine), he said that when a customer asked him to fit a premade cage the customer was confused as to why it would cost the same as just building a custom one. He said to me with the amount of cutting/rewelding you have to do on them you might as well just have a custom one to your needs!
Fletcher
Any ideas when yours will be finished mate? I'll have to have a good look around your cage :)
Oh and Fletcher, your a yobbo now with them pops and bangs! ;)
:eek:
Fletcher
performance and mechanical wise, do these pop 'n' bangs have an effect? better/worse?
Performance wise, I'd pretty much say it was the same as the Fastchip 98 ron map I had on previously. If anything it feels slighty better (this may just be a placebo effect mind)
Mechanical wise it's to early to tell, only rinsed about 2-3 tanks so far with the overrun map fitted. It can't do the car any good though!
Fletcher
Well it looks like the 172 project will now be on hold for the rest of the year. (bar small cheapish mods) :(
....As I am about to start a large home extension, and ATM my expendable cash would be better spend on this rather then a 9 year old French hatchback ;)
Normal progress will resume soon after though..
Fletcher
I don't mind if you do.
A (matching) passenger seat is a must though :)
Yep.
Well it looks like I need another new alternator, as the current on keeps on over-charging the battery :dapprove:
Hopefully I'll get to and from FCS ok new week ;)
On a more positive note I have finally fitted some front silver visions, and 197 RS badges :approve:
