Here goes,
Firstly I really have no idea where to begin with talking about selling my car.
I've owned her for the last 8 years of which in that time I've poured my heart and soul into it.
I've reached a time in my life where I want a new direction. I'm a huge car enthusiast and would like a change, maybe even sit on the sideline for a bit?
I have absolutely no reason to sell so am in no rush whatsoever, I may even decide to keep her if nobody offers me a fair price.
No expense spared meticulous build, and built as a package to be a monster, S7 WRC inspired road car, she has her carpets and air conditioning.
She has been fully documented throughout her life and has many custom parts and details. I've put way over £60K into this car and literally thousands of man hours.
Her life is documented here:
http://bbs.scoobynet.com/projects-4...-edition-v7-sti-the-t26-wrc-build-thread.html
This car has been maintained regardless of cost and wants for absolutely nothing.
Just love it the way I have/do.
2002 Prodrive Edition STI Type UK
47K miles (2,800 miles on her built engine and performs beautifully)
Blue/Black pearl
MOT and Tax.
Only ever driven on Vpower or Momentum99
Always warmed up and cooled when used.
Here's her full specification:
Built entirely by myself (Frayz-Engineering)
Mapped by Simon Roe (JollyGreen Monster)
Engine
New EJ257 block (modified by FE)
New EJ257 crankshaft
ACL race series main bearings
ACL race series big end bearings
Lateral Crower "long" H section forged con-rods
Lateral Wiseco custom pistons
RCM modified oil pump
Cosworth sump baffle plate
XWORKSS baffled sump
JDM Spec C long runner intake manifold
10mm Phenolic spacers
Walboro lift pump
Custom swirlpot
Bosch 413 Motorsport fuel pump in custom FE QR cradle
Fuelab billet filter
Custom FE fuel rails
Injector Dynamics 1000cc injectors
Fuelab FPR
JDM "Big Port" Spec C heads (modified by FE with custom combustion chambers and port work)
Supertech Stainless/Nitrided intake valves
Supertech Inconel exhaust valves
JDM Spec C cams
NGK Racing 8 spark plugs
PE Kevlar timing belt
CDF billet timing guide
New Genuine OEM waterpump, piston rings, gaskets/seals
GT-Spec Gen II, Zircotec ceramic coated tubular manifold
Custom T-Logic twisted inconel up-pipe
Garrett GT3582R turbocharger with Tial .82 V-band housing
DEI titanium turbo blanket
DEI titanium wrapped downpipe
Custom XWORKSS twisted downpipe
Tial 44mm External wastegate
Bespoke 3" lightweight race exhaust system from Simpson Race Exhausts. (Ceramic coated with bent down tailpipe)
Grimmspeed EBCS
3bar map sensor
160mm K&N filter mounted on custom 6x4 carbon intake trumpet
Custom FE/XWORKSS breather system and RTS catch tank
Exedy Hyper Compe-R twin plate carbon clutch
Exedy Hyper Compe-R forged billet flywheel
Goodridge braided clutch line
APS DR725 front mounted intercooler with custom FE pipework
Hardrace engine/gearbox mounts
Setrab 19 row oil cooler with custom FE housing
Ixiz-Concept bonnet dampers
Odyssey PC680 race battery
Hand built custom engine wiring harness
Samco hosing - coolant
Speedflow Fittings/hose - fuel
Power/Torque limited to 573bhp-520ftlbs @2.1bar
ECU
Syvecs S6 (Launch Control & AntiLag) with 8 individual cals adjustable on the fly
Braking system:
AP Racing 6 pot CP7040 calipers, 356mm AP grooved discs,
Pagid RS29 front pads
Colour coded black/yellow STI rear Brembos
Performance Friction Z/compound rear pads
Goodridge stainless braided hoses all round
Motul RBF600 brake fluid
Suspension Modifications:
Whiteline adjustable front sway bar
Whiteline adjustable rear sway bar
Whiteline HD mount kit
Whiteline camber bolts
Whiteline rear diff locking kit
Whiteline roll centre adjustment kit
SD Motorsport solid rear diff mount
KW Variant 3 External reservoir coilover dampers
CDF billet front ARB drop links
CDF billet rear ARB drop links
CDF billet pitch stop
CDF billet anti lift kit
Super Pro poly lower arm bushes
Super Pro poly outrigger bushes
Super Pro poly gearbox cradle bushes
AS Performance delrin gear linkage bush kit
Noltec billet clubsport pillow ball adjustable topmounts.
Custom STi front strutbrace
Custom (track bias) geometry setup
STI8 Spec C steering rack on Whiteline bushes
Wheels/Tires:
18x8 Speedline Turini
235-40-18 Michelin Pilot Super Sport
RAYS extended black lugnuts
Genuine Prodrive valve caps
Interior/Exterior Modifications:
Interior
Prodrive/Sparco Pro WRC carbon drivers seat
Prodrive/Sparco Pro WRC GRP passenger seat
Flocked dash with custom gauge pods
Flocked A pillars
Flocked Steering column cowlings
Flocked centre console
Satin black dash trims
Speedware stainless harness bar
WRC/Group N carbon rear firewall
WRC/Group N carbon rear seat bench replacement
WRC/Group N carbon 3 piece parcel shelf
TRS Magnum ultralite WRC FIA 4 point harness's
Genuine STi carbon door sills
Genuine STi mats
DSG white delrin gear knob
Full Works Bell QR steering setup with Momo Mod 07 steering wheel
Lifeline 4ltr plumbed in fire supression system
Lifeline 2.25ltr handheld fire extinguisher
Exterior:
6000K HID lighting (High-Low)
Carbon STi wing blanks
Genuine Prodrive WRC S7 Carbon mirrors
Genuine Prodrive WRC S7 Carbon bonnet vent
Smoked side repeaters
Custom gurney flap on upper wing blade
Custom fog light covers with flush mounted cold air feeds. (oil cooler/air box)
Genuine Spec C type RA roof vent
WRC plain black Kaylan mudflaps
Polished/painted Prodrive rear diff guard
PIAA Silicone wipers
Aerocatches
Data acquisition:
Syvecs S6 ECU
Defi BF 60mm gauges - Oil Temp, Oil Press, Water Temp, Fuel Press, Exhaust Gas Temp, and Boost Press.
RB Motorsport ACT gauge
Innovate Motorsports Wideband Lambda sensor with USB hub output
Phormula KS3 knock analyzer
If you're wondering, she sounds like this.
Frayz-Engineering STI Anti-Lag Test - YouTube
Frayz-Engineering 576bhp Prodrive Edition Sti - YouTube
I have literally thousands of photos of his car throughout her life with me and can supply further information to any genuine enquiry.
As said, I do not need to sell her and at the moment purely testing the water if I get the right offer or not. Spares and registration not included in sale but are open to negotiation.
No tyre kickers
No test pilots
This car is truly unique, there is not another built quite like it. To me it's absolutely priceless and has taken a huge part of my life.
Must be seen to be appreciated and any inspection is welcome.
Still don't actually know if I can watch it drive away but will be listening to offers over £25,000
May be interested in a possible PX for MK1-2 escort, Cosworth or something interesting.
Thank you for reading.
Frayz
