Right just a quick question:-
How much better is the willy than the 16v round corners and in terms of general handling? Would you notice it alot between the two cars or is it just noticible?
Its noticeably better, (its those Renault 19 components that make the difference..)![]()
Hubs, driveshafts, wishbones/ball joints and shocks/springs - You can basically find a rear ended/breaking R19 16v and pinch bits off it, maybe buy the wishbones new as theyre so cheap anyway - also I believe Williams shocks are different from R19 even though theyre the same dimensions.Quote: Originally posted by G16NNN on 17 February 2004
What exactly would such a retro-fit entail then?? :s
Its not that the R19 parts are very good, just that the Williams uses them very well and is very well set up. Trust me, ive just been driven in one of the best example of a Williams left, on some of the greatest roads in Britain, flat out, wheels up, by a trained racing driver. Yes i was scared. Not so much for personal safety, but more of the large rocks and grazing sheep and ponies at the side of the road comming into contact with the flimsy bodywork of the car. And i can assure you very very very few people are qualified to state how well the Williams handles as very very very few people are actually able to drive it anywhere near its full potential. I thought i could drive it fast until this day. Im not even getting 80% out of it. When its up to speed it will grip like any supercar (not my words, but those of the driver). Its just that it takes that little bit longer to get upto those faster speeds. However, on some roads that is not so much of a problem.Quote: Originally posted by Daz on 17 February 2004
I knew the Williams had 19 16v suspension, but doe sthat mean the 19 16v handles better than a Valver? Or does its extra weight/size make a difference?
NO, IMO.Quote: Originally posted by G16NNN on 17 February 2004
Well surely a valver on coilovers set up well would outhandle a standard willy on a track??
Quote: Originally posted by mike8579 on 17 February 2004
Tyres is a different matter fella. Tyre technology has moved on quite significantly since the Willy was developed.
Im sure Renault wouldnt have settled on the Pilots if they were developing it now. Plus, Michelin are a French company, and Renault being state owned would tend to opt for French tyres I wouldve thought.
Your quite right, Renault may opt for a different tyre if the Williams was developed now. However, it wasnt. If you change the tyre, you are changing one of the most fundamental aspects of the car. All the set-up work relied on the michelins. The stability of the car in corners and braking was controlled through suspension parts that was designed around those tyres. Changing the tyres would be like changing the springs to a diffent spring. A spring is a spring, does the same job, but you cant argue that it wouldnt effect the cars handling.
Most people who change tyres do it for the reason of cost. The fact is the Michelin Pilots are expensive. Other tyres maybe 1/2 the price.
Of course but i think what hes trying to say is that tyres now are better than tyres then so surely changing the tyres will affect the cars handling POSITIVELY??Quote: Originally posted by king.stromba on 17 February 2004
Of course but i think what hes trying to say is that tyres now are betterQuote: Originally posted by king.stromba on 17 February 2004
Remember we are talking about tyre SIZE not compound. A 185,55,15 is a 185,55,15 (assuming same manufacturer). But you could get it in different compounds. Im talking about size. For example the speed rating differes amongst tyres of the same size and manufacturer, with the result that one wears faster at higher speeds. If however both tyres are new, there would be little difference between the two in terms of grip.
NO. Using a different size, even if a latest tyres will affect the cars handeling NEGATIVELY
Likewise for uprating other suspension parts??
NO. The Williams already has uprated suspension in that it has been setup to run this suspension. If you claim to be better than Renault Sport at Suspension geometry setup, feel free to have a go.
After all as much work as Renault did on the handling of the willy - as with all their cars they were limited to constraints by the fact that it was a mass produced road car!!
But was designed to primarily handle well. It wasnt a compromise car as much as something like a 172.
Whereas an individual owner would be willing to lose some of the comfort of the ride in favour of better handling performance?
If you feel you can improve the Williams please feel free to try. If you do you will probably just end up destroying that Williams feel, which is in essence why it got its reputation. Read the latest Renault brochure on the 182, V6 and Cup. There is a small section on the Williams - Quote unflappable poise on cornering Best Hot Hatch Ever. And thats in a brochure trying to sell the latest cars.
Why assume that newer more technically advanced tyres will have negative affects on a cars handling?
I would much prefer to have some state of the art tyres over some that were designed over 10 years ago, regardless of whether or not a car was tested on them!
IM NOT TALKING ABOUT COMPOUND, IM TALKING ABOUT SIZE AND MANUFACTURER. Is that clear enough for you? A standard size Michelin Pilot will always work better than a different tyre on a Williams
Well enjoy your trip into the scenary then, when your state of the art tyres fail to grip the road correctly and transplant you into the nearest tree.
