HELP ON ENGINES FOR CLIO 182
Car  Titanium PH1
Hello people im in need of help i have bought a 2004 182 with bottom end gone and i have a phase1 172 engine been finding information and im seeing all different stories so i was wondering if i would be able to drop the phase1 engine straight into the 182 fitting all the 182 parts/accessories straight onto the 172 engine without any problems and is there anything that i will have to alter to the engine? cheers
Ph1 head is better.
The engine will fit fine with all your bits bolted on. You'll just need the inlets, breather plate and throttle body off of your 182 and all the aux setup too.
i have the engine running now in my 182 it is all idleing fine i have hat the bloke the one feed off on the rocker cover where it goes into the inlet is that okay? cheers
