Hi Guys
Well out of this little lot
Fit KW v2 suspension (front rear)
Fit front brakes and discs
Weld front wishbone bushes and refit (doh)
Fit front brake lines
Fit front ARB sensors (smashed the other ones getting them off)
Fit ARP rod bolts
Paint engine
Clean and then paint gearbox
Fit cambelt kit
Fit Air con delete kit
Get dash flocked
Remove dash bars/metal plus any other brackets inside I have missed
Remove roof sound deadening
Fit plastic door windows (fronts only)
Fit steering boss and quick release
I got this done
Fit KW v2 suspension (rear)
Weld front wishbone bushes and refit after being re powder coated
Fit ARP rod bolts
Paint engine
Get dash flocked (sent it away)
Fit steering boss and Lifeline quick release
Grind off steering lock and other column brackets and then get column powder coated
Removed fuel lines
Removed flywheel
Removed Clutch
The car is being picked up tomorrow to have the cage put in so I am fitting standard front suspension while they do that. I shall post up pics of all the recnt bits I have aquired
The calipers I am VERY pleased with and also the KWV2 looks great, very pleased.
Took the decision NOT to tune this engine. I am putting this car back together with an albeit standard engine so i can get out on some track days and learn setups. I am buying a second engine which I will develop alongside the car as my bad ass engine
This will enable me to use the car whilst building an awesome race engine at the same time.
Pics to follow.
PS
I wanted to order some new rear subframe bolts but when I rang Renault he said they come in 3 lengths? Trouble is one of mine is odd so im not sure what to ask him for? Any ideas here?
