Intermittent Chirping Sound - Belt Area
Amos91
Honorary Member
I was going to have a good look yesterday but it was far too cold! Anyway, got an odd sound coming from the 182 which I hope someone has heard before... It an intermittent chirping sound which sounds like its from the belt area.
A couple of things to note -
•Heard a blocked breather could make the oil pump noisy but removing the breather makes no difference (nor does intentionally blocking it)
• Cambelt, Dephasher and Aux kit changed in Jan 2015 by a specialist
• Faulty alternator replaced with a genuine (new/refurb?) in Sept 2015 with a new aux belt
Here is a very quick video I made -
Thanks,
Amos
It does not sound like the oil pump. I had the blocked breather causing it.
You could try narrowing it down by using a long screwdriver, ear to handle and tip to various areas on the car.
Caution-moving parts!
Hopefully someone will be along to help.
Some belts are just noisy at times. Search for ChrisFix youtube video on noisy belts for help identifying the cause. I rate his videos very highly.
