Ive Got It And It Rules !!! - Clio GTT
  Skoda Fabia vRS
anyone thinkin of havin a GTT conversion, get it done, and get it done properly at GDI, sweet jesus its good, its a totally different car
oh, and if the handlin of your Clio is crap, get some GAZ coilovers and polybushes, the difference is amazing, words cant describe really how much better it really is
an even though im limited to 3500rpm for the time bein, its superb !....the pull of it, totally wipes the floor with my old engine in every single respect
dump valves rule !!
Andy has done an absolutely superb job of it, its so tidy and neat and the car runs really well, i couldnt be any happier i dont think........
my normally rediculousy loud exhaust has now quietened quite a lot but is now a lot deeper, i prefer the sound.......
i cant thank Andy enough for all the hard graft hes put into it, workin early-late for about a month almost solid, makin sure even the smallest of jobs was sorted out to a very high standard
called in at the ClioSport North West meet so no doubt a few of the lads will let you know what they think of it.....
and no Jon (2live) im not racing you yet !
CHRIST ITS SO DAMN GOOD !!!
pimpage - Grey Devil - 07010 716440 !!!
  GDI Demo 182, Rsi Spider
glad you are happy mate...
even I was impressed with the way the car drove.... the handling felt just right....
150 lb front springs made all the difference
  Skoda Fabia vRS
yea definitely, the harder ones would have been too hard, whatever setting you have put it on seems really sweet, it grips like never before, body roll is very minimal, hardly any
  Skoda Fabia vRS
7psi at the moment while its run in mate....
once ive done 500-1000 ill be takin it back down to Andy at GDI for him to work his magic on it again and put me up to about 14psi i think
  Skoda Fabia vRS
well if anyone wants to come have a look at it, i work at Motor World in St Helens...
  300bhp MR2 Turbo
What was it before you had the conversion done mate?
I saw the pictures and the engine bay look sweet.
  Skoda Fabia vRS
a Clio 1.4RT.......
  300bhp MR2 Turbo
I used to have an RT and I blew the engine up last year, I thought about sticking a GTT lump on but didnt know any one that did it.
Was it Andy at BB tuning that did the conversion for you?
  Skoda Fabia vRS
no mate, Andy at Grey Devil Industries in Caxton, Cambridge
hes done an excellent job of it, hes certainly got an eye for detail...
  Skoda Fabia vRS
here is the proper spec
1400cc 8valve Turbo Charged (Renault 5 GT Turbo)
Standard T2 Turbo
Standard Intercooler
Standard Carburettor
GDI Gasflowed stage 3 Head Inc:
· Reworked combustion chambers
· 3 angle valve seats
· Gasflowed and Ported inlet and exhaust ports
· Flowbench tested
· Matched and Gasflowed manifolds
· Chemically cleaned
GDI reworked rocker assembly (Quietens tappets with performance cam)
GDI Piston and Liner set
GDI wire ringed liners
Mellior 2.2 Head gasket set
12.9 Uprated Head bolts
GDI Dished piston crowns (for improved squish)
GDI Balanced:
· Crank,
· Flywheel,
· Clutch cover,
· Pulley wheel,
· Con rods,
· Pistons
GDI Superlight and slotted flywheel
SFS Silicone Water and Boost Hoses
Uprated Valeo clutch kit
Piper 285 Cam
Piper Uprated valve springs
Braided Turbo Oil Feed Line
Single Wiper Conversion
GT Turbo dashboard
Autometer boost gauge, fitted to 16valve gauge pod
ECU and Electronic Fuel control system moved to scuttle tray
Battery moved to scuttle tray
GAZ coil over suspension system, with 150 lb front springs
Polybushed wishbones and anti-roll bar
GT Turbo gearbox
Clio 16valve Driveshafts
GDI Uprated engine mounts
Modified subframe to accept GT Turbo engine
  Skoda Fabia vRS
ive lost count mate.........and yes, it is worth it...
not took anymore pics yet.....but i will be
KDF
  Audi TT Stronic
Ye its sounds well smart, you will have to get some vids of it in action too.
  williams and trophy
hehe dont forget brun mate.....
u gotta give it a bootful evry now n then jus to run it in proper ;)
n wens this race?
BRUN, if i were u, dont put ur psi above 12psi, ur turbo will start stalling when u really hammer it.... i had my R5GTT set at 14psi and when really hammering it through the gears the engine & turbo would start too stall from fuel starvation, and i had uprated the fuel pumps etc. also start risking the standard intercooler to blow apart after 12psi, and turbo cant take much more
  Skoda Fabia vRS
thanks for the advice mate, ill see what Andy says when i take it back to be tinkered with in a few weeks
  Clio 172 cup
Brun have you got an adjustable timing sensor yet?
it is highly recommended that you use one of these babies if you plan on using ordinary unleaded petrol
Jim
  Clio 197
y does it matter , i bet they werent run on optimax back in the late 80 s as standard cars. ...ok its not standard but aint it a bit OTT?
  Skoda Fabia vRS
Quote: Originally posted by The_Raiderman on 02 December 2003
Or you could just use optimax with no problems its just as we know a bit on the pricey side:cry:
i only ever use Optimax mate, always did in the old 1.4 E7J engine...
Because back then, there was this thing called leaded petrol! ;)
MaLicE
Honorary Member
  Lazy v8
i can still get propper leaded petrol:D
live near lots of farms so local garage still stocks it :D
