My new Fabia splitter came last week and was swiftly fitted, as the old one was a bit worse for wear.
I've trimmed it down so it doesn't catch the wheels on full lock but it still needs trimming to sit flush with the end of the bumper.
Old:
DSC_0038 by
jggd51, on Flickr
New:
DSC_0041 by
jggd51, on Flickr
It wasn't very noticeable when looking at the car as a whole but it's been bugging me, so it had to go.
Next up the car hit a big milestone in it's life:
Untitled by
jggd51, on Flickr
A celebratory service will be carried out in the next month as I like to change the oil and filter every 6,000 miles, and it was last done on 95,000.
I also dropped my TPI bolts off with a family friend for him to trim down and managed to go and pick them up in the week. When I went into his workshop I was greeted by this beast:
Untitled by
jggd51, on Flickr
A 1932 Ford Model A, to which I also offered to give a full clean and machine polish in the Spring/Summer as a thank you for doing the bolts. So I'm looking forward to that (if he takes me up on it)
He took about 2mm off the bolts and this is how they turned out:
DSC_0049 by
jggd51, on Flickr
I got them fitted yesterday and they're not bottoming out on the hub now and all is good once again.
My xenons also started to play up at the start of the week with the n/s one deciding to give up on me and start glowing a bright pink:
Untitled by
jggd51, on Flickr
A new pair of 6k ones were ordered and fitted yesterday too. All was good, I thought, until I managed to open the garden gate on to the rear bumper which gave it a great big graze and also a nice crack:
Untitled by
jggd51, on Flickr
You can see part of the damage the gate caused in the bottom corner, but the whole area is about 10cm across. I'm feeling a bit unlucky and gutted that it turned out as bad as it did, but at least I've learned my lesson regarding parking my car too far back on the drive.
A new one has been ordered and from what I could tell with the pictures looks in very condition. Looking on the bright side, this will also give me a spare number plate light casing that I can hopefully clean up/wet sand and get it a bit clearer than the current one, albeit a more expensive way than just buying a new one.
The weather was nice today and instead of cleaning the car (after the fiasco with the rear bumper) I decided to go out for a spirited drive around some local B roads and then on to some country lane exploration.
Here's a few pics I took:
Untitled by
jggd51, on Flickr
(I forgot I had the camera with the first lot)
DSC_0085 copy by
jggd51, on Flickr
DSC_0058 copy by
jggd51, on Flickr
The car drove spot and felt nice and tight, however the brakes didn't feel the sharpest. I checked when I got home and there isn't much meat left on the pads so soon I will be buying some Brembo HC discs, OE pads and some ATE Super Blue fluid. I was debating on whether to get some Mintex M1144 but as 90% of the car's life is going to and from work, I didn't feel they would be much use.
