Popped over to see Mike (not the grinder wheeling car breaker Mike) at lunch time to progress with the cage fitment.
He specalises in entire chassis builts for sillhouette racers and hot rods, only a young chap/one man band but extremely talented. Makes a lot of lovely exhaust manifold systems for all types of race engines.
Small workshop but exquisite workmanship:
Anyway, pretty bits aside: The skeleton of the cage is all in spotted in place, the rear 'caged' bolt in unit has also been welded in to the reinforcement points with the front section desgined off it. The caged unit is designed to clear the internal headlining/plastics etc, so as a result does sit a little further away from the bare shell than Mike would have preferred.
Sections such as the door X beams will have box sections in either horizontal angle, and stiffening gussets are going to be run down the A pillars.
Sorted out the dash bar for the mk1 dash fitment.
Due to be collected on Thursday (ish), but I'm not 100% if I can collect due to work comittments.
Once the engine is back in etc Mike will also be building the car a new exhaust system.
