Cub.
		Love this project. Great work! 👍
			Just on the hunt for some seats now, what sort of price did you pay? Agree, I have it in a nice position at the moment but it is right up against the bulkhead. I will follow you guide on here and if I get stuck I'll come a-calling@VenomUK dead easy to fit fire me a pm if you want any advice. Bulkhead does limit leg room up front, my old 68reg one had it and struggled to get position right with stock seats.
Bloody hell, to think I almost pulled the trigger on a pair for £600 the other day with worn bolsters, your set look mint mind!! I need to shop aboutI got my seats for a bargain £400, a good pair seem to be anywhere between £600-800 if you want a mint set. This set needed a clean with a wet vac and had to paint the inserts up. Dead easy to fit though, pm me if you need any advice
Small job done tonight after gym. The meg 250 inlet has a breather solenoid fitted which i dont have and is about a ton new. I wont be needing it as basically emissions crap as far as i can tell and i will be running a catch tank setup from the breather plate.View attachment 1501480
Anyway tried sniffing out a 2nd hand valve to blank the hole but no joy, was considering sending it to the local fabricators to get it gone permanently but have not had time to drop it off.
Browsing ebay and seen some bmw swirl flap alloy bungs with o ring, same diameter as the hole. Bought one for pennies and it fitted the hole but was a tiny bit slack, so fitted a small o ring under the original to nip it up, which has made it a really tight fit. Had to chop it about a little to get it on but looks alright.View attachment 1501481
Tempted to send it, what does everybody reckon?
Facelift looks good too
Ive not measured the wheelbase but by going with online figures its 2312mm, compared to clio 2 @2471mm and clio 3 @ 2472mm, so a bit shorter. Track wise its supposed to be very similar to meg, i guess id need to measure it up as it wont match book figures now its on the megane rs front end. Im hoping it all works ok and it can be chucked all over without too much drama but will see.The wheelbase is hilarious. It looks like one of those chopped down VW buses. Be interesting to see how it handles. How does the wheelbase/track compare to a Clio/Megane?
I bought it from this seller on ebay, if you message them they will do you a custom listing to suit. Quality seems good https://www.ebay.co.uk/itm/232001967078@Brigsy Where did you get the Lux suede gear gaiter from?
