No, hoping to go with this
Going to be quite tight for space, but I'll know better once the seat is mounted
Are you gonna to upgrade to gidraulic clutch pedal?
This is one of the very few threads that actually interest me on CS, so an amazing amount of work done and mostly by yourself! Would love to have the knowledge etc to do this, really cant wait to see the finish piece. Should weigh hardly anything and with the trick suspension geometry/modifications should handle well also!
Once i've done the other side, ill make some gussets to stiffen them up.
I had seen those kits from pure-motorsport but decided to go with the uprated poly bushes.
Been advised by someone who knows his stuff regards suspension that if your running the car on perfectly smooth circuits fully rose jointed suspension can be of benefit but in most situations you need some compliance in the suspension to allow the tyres to bite.
The competitions i'm going to be doing, the surfaces are fairly good in most cases but definately not billiard table smooth
I'm just going on what I've been advised and from experience there is merit in keeping some compliance in the suspension pick ups.
A touring car will most likely have rose joints everywhere, but they tend to run on very smooth surfaces and have a huge budget to work and develop suspension etc.
A rally car in tarmac spec is a totally different beast to the above, they're constantly changing direction and nearly always on the slide so although they may be quick on tar they go about it in a different way, on gravel, well thats a whole different ball park and not something I'm interested in so cant really comment.
Confusing post....
Having done racing and rallying personally then i can comment, rose joints all the way for any surface is an improve ment. The only reason people dont do it is cost. Careful who you listen too as 99% on here is Chineese whispers.
Great build, very impressive amount of time commited.
During last yers I try:
1) Original wisbone bushes
2) Powerflex (not two reliable, need to change them twice in a season)
3) Originall cusom filled by hard polyurethane:
http://www.cliosport.net/forum/show...-from-Russia&p=7647443&viewfull=1#post7647443
(with some attidional stiffering rings wedged around the bushes mounting holes) - much better the Powerflex
4) Bearings - like them the most
By now I make some alloy triangle wishbone arms with bearings:
http://www.cliosport.net/forum/show...-from-Russia&p=8248932&viewfull=1#post8248932
- but did not try them yet (will install on the next week).
P.S. Well, I am not rally but touring...![]()
Well, camera took more than 10 today but not by much lol
Got the passenger seat rails progressed, starting to get a bit better with the mig, will leave the bit onto the tube for my mate to TIG
My mate is coming up tomorrow to finish the seat rails, got some more bits for my steering column today so will hopefully crack on with that tomorrow.
Kenny.
The wishbones look very nice! as does the blade anti-roll bar, do you intend to sell these?
Very very impressive build, very impressed and jealous of some of the work / ideas going in here,
You are very lucky to have that work space and be able to weld also, from my point of view being able to fabricate would cut a massive chunk of £££ off my build...
instead i have to rely on a mate (who is a painter / sprayer) and although he is a mate he still has to run a business....
just a point and a couple of questions though if poss....
my first point, have you thought about loosing the rear wheel well? i have just removed mine, considering what you have already spent on the car its not that much of a spend out, it will save weight and will also allow you (if you wanted in future) to look at diffuser's as you are left with pretty much an open space from the rear axle back to the bumper.... oh and the fact you can weld will mean it should be a pretty easy job....
search my thread out if your curious what i mean
the next thing i was going to pick your brains on was the seat rails, i am currently mid build on mine and am still prior to paint so still have the option to fabricate parts, i was going to be running extra low (custom) subframes on the original seat brace locations but am very much thinking this will be a better way to do it, did you fully fabricate your own set up from scratch?
Cheers,
Yeah the workshop is pretty good considering what it cost me to build it, just fortunate to have a mate with a huge barn thats largely unused, I pay his old dear something every month for elecy and I've got free rein to come and go as I please, dont think I'd be able to build the car if I didn't have this place or else I'd be paying a lot more to rent something.
Saw the update in your thead regards the flat floor, I have thought about doing this too. Having removed the towing eye and stiffening plate from the wheel well, it's very thin, guessing 0.8mm possibly less so not sure how much of a weight saving there is to be had?
It would though as you say make it possible or certainly easier to run a diffuser. I've still got a while before the inside of the car is ready for paint so I'll keep it in mind but as it stands I'm inclined to leave it as is. It's not that much work to do the flat floor at a later date, just a wee bit of paint inside but that shouldnt be too hard to sort.
The seat rails were indeed made up from scratch, the kits from Custom Cages are £80 a side, found it hard to justify that so made my own.
I had some 40mm x2mm T45 tube knocking about anyway but to buy 2mtrs is about £45-50 i think. The brackets were made from 40mm box section with a 3mm wall, costs hee haw from any local metal fabrications place, most will give you wee offcuts for a fiver or less. The strengthening plates were made from 3mm plate again not a lot of cost involved with those either. It was quite fiddly and time consuming but also quite satisfying too (i'm sad like that) If you want to have a go at making your own feel free to ask any specific questions and I'll do my best to help.
Kenny.
The kit from Custom Cages uses 40mm x2mm tube, Demon Tweeks looks like 25mmx2mm and T45 vs CDS, either will be fine though. Mine basically cost me nothing, cant remember when I bought the 40mm tube but worst case both sides owe me about £50 all in.
Yeah the holes have been flared, I made up a wee tool on the lathe at workrecon ill prob make a 25mm one when I'm away again next trip.
Flaring the holes will strengthen them![]()
