Keith185
Re: Boosted BlackGold Project - F4rT content.
Awesome plans for it, can't wait o see the progress
Nice one! Andy seems a really decent bloke given me lots of advise. Pictures of your manifold/down pipe would be handyBeen in a meggy 255 is nowhere as awesome as F4RT in the clio, I went out in one before i did my conversion, the power is amazing so smooth and hardly no lag if done properly. Andy is a great guy and helped me sort mine last yearIf you need any help or photos etc on bit mate let me know.
For manifold ive got the standard 225 then fully custom downpipe, i can get a picture if you need??
Depends if you wanna run abs still, ive got rid of mine and i run fully stand alone on adaptronic
keep the updates coming![]()
Superchargers are one of those things that just seem epically cool and amazing but actually arent really so great in reality IMHO.
You end up with worse fuel consumption, if you go displacement they dont like to rev generally speaking and if you go for a rotrex type then they are expensive and fragile.
Only real upside is not having lag, but TBH if you keep a turbo car in the right part of the rev range (not hard when for example on my turbo 172 that sweetsport is all the way from 3500-7500rpm) you dont suffer much with that anyway.
Turbo also allows far better control of the boost you run and can hence be mapped to different throttle angles etc if you use the right management (will be doing that on mine later on)
These are the reasons that manufacturers all seem to prefer turbos generally speaking.
Been working on mine today and had a good look for where your manifold could run but can't quite picture what route the down pipe can take. Will be keeping a close eye on this one!
If you go the cast manifold route let me know if you need any help with the brake issues.
This is it, just got to make it workGood luck with the manifold lewis, that engine was for a kangoo van not a clio.
Anything will fit, its just the lengths you'll go to, to make it fit. Thankfully T.Trophy has dropped off a lovely log manifold for me so I wont be f4rting () around with moving things
Apparently someone who changed the brake/abs/master cylinder set up on there turbo clio was atroscious (sp)This is it, just got to make it work
By log manifold do you mean the kind engine dynamics & k-tec sell for the f4r conversion?
I'm in 2 minds as to try and use one of them if the custom one i have turns out to be a PITA.
The main thing i dont want to p*ss about with to much is brakes, i want to leave them mainly as they are/not do anything custom on them as if they fail it could go badly wrong. Although if the ABS unit is in the way, i have no problems swapping to a cup setup.
Oh right, sounds dumb but i didn't know Scoff was EFI-parts! Andy has been recomending EFI but had never heard of them so been a bit cautious! Now i know who it is i'll definatly be using themScoff at EFI Parts is a top bloke and has given me loads of advise on my setup. I'm booked in on the 7th Of July for wiring and mapping and can't wait. He really rates the adaptronic stuff and as Rob says, he's used it to get unbelievable power out of his R5.
Now that I know what to do to clear the master cylinder with the down pipe it's not that difficult but part of the fun of doing a conversion is finding this stuff out and finding solutions to the problems you face. It's all too easy to give the car to a tuner or whoever and get them to do it but from what I've seen you look like someone who wants to do it yourself and get the feeling of achievement by DIY.
Enjoy!
Yeah the log manifold is the ED/K-tec one
If you want big power the log manifold is a bad idea, the runner on cylinder 3 is extremely short compared to 1 in particular, so you end up with pulses colliding which cause higher EBP and with 3 being so close you risk overheating the exhaust valves on that cylinder, especially if you are on standard ones which are bad to begin with.
Should be, have most of the parts now, once the white shell is gone I'll startSide mounted will look awesome imo.
So is than plan to have this ready for the ring?
Just my existing F4R mate, was thinking GT28RS although I hear the new GTX range are really good, I think paul runs one on his megane R26.RI can see it easily causing problems if you start moving it all...
Ah right, are you using that on a F4rT or F4r? What turbo will you be using?
28 is too small for 2.0 litre I reckon.
I'd sooner run a 30 and just have it ticking over for 300-350bhp than a 28 flat out.
Egt and Ebp is lower that way too.
Money really is a main factor on this. If my cammed engine doesn't sell I'll sell the cams and have it rebuild at a later date forged with a megane head for a huge turbo.^^^ This!
Should be a good build this, take advantage of the side mount and use a big turbo! Strap a GT30 onto it, stick some ARP's in there and aim for 400. Piece of p155! Not as hard as you think to build a 400+ clio is it, and if you're using standard engine bits then they're easily replaced if it goes tits up
Just make sure you've got a spare gearbox or 6!
I'd keep an eye out for a SPARE Megane/Laguna turbo engine or head as well,
I'd keep an eye out for a Megane/Laguna turbo engine or head as well, they can be had for very little. If you take your time you can find stuff for a big HP build for fairly cheap. I suppose using a standard turbo and collecting all the big bits is a good way to do an upgrade and enjoy it at the same time...
Lewis has the Megane Bottom End, 225 Pistons, Rods and the 225 Head already mateIt will be great up to 300Bhp
With some ARP's it'll do another 100 as well, someone will prove that soon enough I reckon, all this talk of the meg engine only going to 300 is tittle tattle![]()
Thanks AndyNow then Boys Play Nice.
Lewis the manifold will fit into your car with no issues ( it certainly WAS NOT ) made for a Kangoo, and even if it was the Kangoo Van has the same engine bay setup as the Clio LOL, as you know some work will be needed for a down pipe and this of course depends on what turbo you go for. The Water bottle will need moved onto the passenger side strut, its just two bolts. I fitted this to our project car with no issues at allthe week before i had to change plans! and that is a clio 172
. This wasn't in the valver, that ran a OEM 225 manifold!
In Relation to the ECU i think the GEN90 is a great bit of kit and will litrally Plug and Play with no major work! As i said the Adaptonic is great and i cant see why Paul would not map this, he did at one point map mine for me, and yes the software is a little dated its still very efficient! running a Hybrid turbo mine made 309.6Bhp at 1.2Bar. and at 1.1Bar 299.8 At RST, so the Ecu can control the car well. The new version of Adaptronic are out and are very very good. Andy Scoff from Efi-Parts.co.uk will certainly map this for you! Look at the top dog R5s running massive BHP are running this ECU.
Now in Relation to the Turbo I agree very much with Chip, some one who acshally knows what hes talking about, with his vast Turbo background. nothing worse than a Limp lifless smooth car IMO, you want Raw and aggressive to throw you into the seat! and 300Bhp does that!
In the case of some posts in here its defo "who you know" and not "What you know" PMSL![]()
I don't know a great deal tbh! Read alot on here, Andyrg has told me the rest lol mpg really isn't something I'll be thinking about...Looking great, wish I had the know how to turbo mine :/, how much does the whole conversion roughly cost and what aorta mpg would you be expecting?
Scoff's already ran 400bhp+ on standard internals, so I don't see what the big deal is. BUT he did use a different crank to lower the CR into the 7's and he ran a large turbo which as Chip says above goes along way to reducing the risks. The biggest problem with Meg engines is there CR and they have a really restrictive turbo/manifold systems so when people start upping the boost thats when they start having failures. Plus I dont think the fuel system without a boost reference helps matters either when butting big boost in them.
Regarding turbo choice etc.... I've driven Renaults with F4R engines that have been fitted with a GT2860R, GT2871R, GT3076R, GTX3071R, stock Meg turbo's and Meg Hybrid turbos. They have been fitted to various manifolds some logs and some tubulars and out of all I still maintain that the GT2860R (on a logg) was the best all rounder for spool, power and response. Yes the hybrid spooled faster but was gutless at the top end, and the GT30's both made more power for less boost but were noticeably laggier where as the GT2860R was slap bang in the middle and gave the best of both worlds, and lets face it anything over 350bhp and your gonna spend more time swapping JC5 gearboxes than driving it.
It was on his drag five and worked pretty well, his philosophy was similar to Wilkys. If he had a piston/rod/block failure its a cheap fix. That was in his early days and hes moved on to higher BHP and a forged lump now.
Think it was out of a 1.7 volvo lump, sure it reduced both the capacity and CR in one foul swoop. Whilst it might not seem the most logical choice it certainly worked. However he did suffer a failure in the form of a bent rod once he went beyond 400bhp.
