It's supposed to be 9.5 taking into account the head etc.Looks like pretty high compression! And how much duration do those cams have? Lobes look pretty big
That crank is a work of art. Where's the fancy pictures of porting
The valves are 2.7mm bigger than the stock 250 on the intake and 1.5mm on the exhaust
Jesus wept! Don't think there much more room for even bigger valves.
Might of missed it but are you running two banks of injectors?
Dry sump mock up build
saw this on FB. . I don't get it but it looks great
The engine oil is not kept in the engines sump, its kept in a tank somewhere in the car.
RSTuning are they high tensile cap head bolts for the main caps? If so what grade? 10.9 12.9?
Even better cheers bud..
They are 12.9
personally I think it needs a girdle too but they seem to think it will be fine.
Are they the same thread diameter to the standard main bolts then? Or have they been time serted to a bigger size?
