Major 182 rewiring today... Excellent!
Car  Clio 197
I never thought I'd finish it!
I've majorly rewired my car today:
1) Live feed directly from battery (fused) through the bulkhead, into the cabin.
2) Distribution block connected to it.
3) From the distribultion block:
(a) +ve feed & new earth to a switchable circuit, controlled via a relay switch (connected via 300W cable).
(b) Direct feed to amp via cable + (instantly removable via banana connectors).
(c) Direct feed to bluetooth car kit (switchable via ignition-on circuit).
4) Relay switch circuit can:
i - Be left "on" via a switch.
ii - Be switched "on/off" automatically via ignition-on signal from lighter socket.
iii - As ii above, but stays on for 2 hours after ingition off via 555 timer chip, so as to leave chargers running (without risk of running the battery flat accidentally overnight).
(a) Feed to car cradle (charger + antenna).
(b) Feed to 4-socket lighter socket extension (independant of car's original lighter socket).
(b) Feed to cooler box.
5) Phone Cradle & Strip-Antenna installed (as described above).
6) Re-located car-kit Speaker & Mic to reduce feedback; re-routed the wiring for the same reason.
I'm pooped now. Anyone wanna make me a cuppa tea?
nice work mate, I am interested in doing the relay thingy. Makes good sense to do it this way, with a delay, as I am sure there aer spikes in current output when you turn key.
Good point there. Sometimes it can affect your equipment, although the transformer for my car kit is pretty good (fingers crossed).
I'm yet to install a timed "stereo off" function - which switches it off automatically when I lock the car.
