Re: Mk1 172 Hybrid Track Car Project
yet another day of my life put into this damn car!!
Set about sorting quite a bit today, few knocking noises coming from up front, exhaust rattling on the bodywork somewhere and brakes (yes again)...
Sorted the knocking (driveshaft/hub nut slightly loose), then spanner checked the rest of the suspension/steering, all good.
Exhaust was next....tried moving it around a bit, but couldnt get the parts of the exhaust to push together anymore than they already were, so decided to remove the system from the downpipe back....big mistake that was
Got it off easily, came to try and get the parts together more, but the pipes were not perfectly round (clamped/unclamped so many times)....so got nowhere with that. Decided to leave it and re-fit it, hopefully adjusting it slightly as it went on....again, no such look...more rattles than before
Last thing was the brakes....they were working pretty good to be honest for a while, rears locking up, so there was enough braking power...
I adjusted the valve as above, then cable tied it fully open, as I wanted to re-bleed the brakes, as I could feel the pedal going slightly once or twice, as if there was still some air in the lines....
Decided to do it the normal way, one person pumping, other doing the nipples etc...this was the procedure I used...
1. All 4 wheels off, on stands.
2. Checked level of brake fluid, cap back on.
3. Pumped pedal hard, held it, undid bleed nipple (furthest away), some air came out, pedal to the floor and held, closed nipple, release pedal.
4. Pumped pedal hard again, held it, undid bleed nipple (furthest away), no air this time, just fluid, pedal to the floor and held, closed nipple, release pedal.
Great I thought, did the other 3 in order exactly the same. I thought, just to be certain I will go round once more, starting furtest away.
Pumped pedal hard, held, opened nipple....more air? same amount as last time too? anyway, pedal went to floor, held, closed nipple, released pedal. Once again, did that one a second time, no air....just fluid.
The same happened with the other three.....seems I get air, then no air....then onto the next one, air then no air, etc.....just seems to be going round in a circle!
No matter how many times I went round the car, air would always come out 1 in 2 two times....why would this be happening? Could it be drawing air in from somewhere? There are no leaks, and they are all new hoses.
