Re: Mk1 172 Hybrid Track Car Project
that's Ok then, guess Twingo stuff must be beefier that Williams stuff![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Check where the bottom balljoint pin goes into the upright, I've seen uprights worn tapered, they'll never tighten up.
Check the bearings you're fitting, I can only comment on the ones in my 5, but the cheap ones used ball bearings, and the genuine ones used taper rollers.
22mm was perfect, the williams shocks are a tight fit onto the hubs, running with 172 bolts too...
