Monaco 172 Track Car
dann2707
Don't put B14's on it, they are too soft for a track car. Hold out for some BC's or ast's😏.
Really?!
Even if they're £350 B14's that are practically new? 😂
Agreed, had them on mine and on track it was far too soft. Especially as you can't adjust the stiffness on them either.
It depends on what the daily driving:track day ratio will be though. For what I wanted they were spot on as they were comfy as f**k just when it came to a track day they really let themselves down. Can't have them all though!
Speedo Gonzales
I've got Grams springs and cup shocks atm, I did Blyton on Cooksports and Cup shocks and it just seemed to roll like f**k
@0ss will tell you, going round left-handers I'm surprised the OSF spring didn't eject and Paul didn't fall onto my lap... Gutted about the 2nd part though :cry:
Flob
Really :( I've just fitted cooksports and was hoping they would be okish for light track use.
Clio_fool
Twas a bit rolly on track, and I found the cooksports harsh on the road and some bumpy parts of my commute I had to take slower than with standard springs fitted.
The B14's I would say feel similar to standard over bumps but don't roll as much. They defiantly aren't stuff enough for track use unless you raise the height to avoid scrubbing. Are stiffer springs available from bilstein?
Speedo Gonzales
I'm sure you can get any springs to suit. I'll still get em anyway just cos I like spending money ffs 😂
Speedo Gonzales
Funny how things change isn't it, when I first got the s**t box a couple of years ago everyone was raving about Cooksports so I just figured I would get them and stopped looking at any other options :cry:
I did the same
Now I've seen the light and how often they snap. Even my Apex ones I ran on my old dCi lasted 70k ffs 😂
Speedo Gonzales
Went for a drive earlier with @Louis @dann2707 @0ss @Sj1782 @Steve
The clio was faultless all day
... until I got about 2 miles from home and it decided to eject hole #3 spark plug😡😭
Luckily I had JUST enough tools to remove the upper inlet and sort it. It threaded back in and I managed to get it tight using a 17mm socket and used a mini prybar as a ratchet🤦‍♂️
Limped it home and parked it up, cunting thing
¹
Dan took a nice photo of it though
Flob
Any ideas on why the spark plug shot out?
Looks very clean in the last shot!
Roads look lovely just did a google maps and you may as well be in a different country - for a moment I was going to ask if I could join you on your next one but that will not be happening
Speedo Gonzales
Not sure tbh, I heard a ticking earlier in the day but assumed it was just a sticky lifter. Apparently not...😂😂
Ill inspect the threads and if its fucked then I'll buy another 172 to break amd a 197 then build a big spec engine and go for nice power
Speedo Gonzales
I like the logic - need new pads - big brake kit, need a new spark plug - high comp engine build. I like where this is going 👍
Mild exhaust blow - turbo kit
Tried to fit my Brembos the other day but I need to start giving them a short back and sides with the grinder😂😂
Before being cleaned
And after
Shame they just don't fit with Rotas ffs
Speedo Gonzales
Having my kitchen ripped out this week and a new one fitted next week. Had to move the clio up the drive a bit to allow a bit more room for the blokes doing the work
In doing so I found Ground Zero for all Covid's, AIDS, Malaria, Measels, mumps, rubella, lung cancer, gonorrhoea, syphilis, HIV and most vaginal yeast infections
I cleaned it with some "anti-bacterial cleaner" and some "anti-bacteial wipes". Let's just see how it fairs😂😂
haimsey
  ph2 172
Mine has an annoying leak, I've been trying to find it for years! I though I stopped it when I pulled the trims out from above the rear windows, cleaned it out and then filled the gaps with silicone. Parked under a tree in the rain...found another way in :LOL:. Can't put anymore silicone on it, if I ever crash I'll bounce!
Flob
And is that a face looking out through all the shite in your garage, some monster made from the worlds supply of Clio parts and cardboard boxes you keep buying
I find you can never have enough fucked cardboard boxes in your garage. If the car was inside (and hence not leaking) the boxes would get all wet.
