Someone's here for you mate
Was it an old or refurbished driveshaft then Kyle?So after the let down at Cadwell I parked the car up and set about diagnosing what had gone wrong. It was clear as day to me that there had to be an issue with the diff seal on the driver's side, the reason how was still beyond me. Getting underneath I could see what had happened
It's hard to make out from that picture what had happened but the sleeve that connects the output shaft from the diff to the driveshaft has slid away from the driveshaft. It decided it wanted to be inside the gearbox, you can just about see the splines if you zoom in
Shaft coming out. Once out I twatted the sleeve down the splines until it was hard up against the shaft like so. It had moved at least 10mm
Which had caused this to happen
View attachment 1651226View attachment 1651228
The seal is 1 piece, the sleeve had smashed the inner part out of it which caused the oil to piss out
Old seal out. Gave everything a bit of a clean after this picture
New seal in
I took the driveshaft to my dad's on the weekend and he blobbed a few tacks on there with the trusty old farmers arc welder. It will win no awards for cosmetics but it will definitely hold
All back together again, I filled the gearbox with ELF NFJ this time, I do have 4 quarts of MTL but I didn't want to throw away £100 over and over and I dont trust the seal not to leak yet. Once it's had a few hundred miles on it I might consider it.
Before I started it up I sprayed a liberal amount of brake cleaner all over my exhaust heat wrap. The seal is right in front of where the manifold comes down above the subframe, when I sprayed it down it came off brown so I'm glad I cleaned it off. Very minimal smoke even after letting it get up to temp
Now moving onto the next issue
RustThat will be a job for winter then
Nah brand new JonWas it an old or refurbished driveshaft then Kyle?
First one that failed I got a replacement, second one I got a refundDid you get a refund on the failed shaftec ones or didn't they want to know?
Do you want an even rarer set of wheels that wont fit and be of absolute no use to you??Some of you may know I'm a proper pervert for wheels. Like to the point I have wheels in my garage that don't actually fit my car anymore
So naturally I bought even more
Braid Acropolis 7J x 15" and 60.1cb. possibly the most rare wheels I own now
The offset means they stick out a lot more than the 2118. More importantly they clean the Brembos with ample room!
View attachment 1654775View attachment 1654776View attachment 1654777View attachment 1654778
Even with the spacers removed they have loads of space!
View attachment 1654779View attachment 1654780
For a second time my upper alternator got a crack in it. Speaking to a few people it's quite common for it to happen
This was why... I've used up all my good fortune with that!
Took off the manual tensioner rod to clean it up. I ended up using all new hardware to mount it as the bottom bolt had stripped slightly too
Got a few more jobs to do before CSF. Mainly alignment and ABS light turning off @Brigsy I might need your expertise of using CLiP to sort my issue![]()
Bfg? Big f**king gimp??
Yes himBfg? Big f**king gimp??
I'm not gonna lie I don't really need anyu more sets of wheels and I need to sell someDo you want an even rarer set of wheels that wont fit and be of absolute no use to you??
Ones that fit jap crapI'm not gonna lie I don't really need anyu more sets of wheels and I need to sell some
What wheels are they?![]()
Had to go look on the last owners build thred on the old datsun pageI'm not gonna lie I don't really need anyu more sets of wheels and I need to sell some
Kyle I'm sure we can redrill them to fit the ClioHad to go look on the last owners build thred on the old datsun pagethey are IMPUL NS-01 R
I think it's the steering angle sensor. That's the only fault I have. Might swap the sensor and then try againIm sure i can sort it, asr issue or abs?
Bradfrod so wouldn't be hardLooks like the garage inventory is worth more than the house....
I keep most of my tools at work these days and most of my wheels are there tooLooks like the garage inventory is worth more than the house....
Aye I've got a few camber shims in the garage, will have a f**k about and see if I can get it anywhere near. Might get the axle stands and string out for that likeShim the rear stub axles so you’ve either got parallel or slight toe in. It’ll help the turn in massively.
Some stuff called shim steel is your friend for this.
Camber shims are ok, but the beauty of shim steel allows for finer adjustment mate.Aye I've got a few camber shims in the garage, will have a f**k about and see if I can get it anywhere near. Might get the axle stands and string out for that like
I've got a fair few pre-cut ones from wafer thin all the way up to 1.5⁰ camber shims mateCamber shims are ok, but the beauty of shim steel allows for finer adjustment mate.
That’s where the maths comes in! LolI've got a fair few pre-cut ones from wafer thin all the way up to 1.5⁰ camber shims mate
It's just the mess about of doing it![]()
Aye making boxes on the floor and measuring from a stringlineThat’s where the maths comes in! Lol
