My Garage build Racetoy, clio 1.
Car  Clio Williams
At start some spec. I try to translate as good as i can.
MODEL: Renault Clio almost Williams;)
Modification :
Engine:
2.0 liter F7R – 183,5 HP, 200 NM
Rebuild head,
Ported inlet, and outlet ports,
Biger inlet and outlet valves,
Rewar 290* camshafts,
Adjustable wheel timing,
PTFE set of gaskets,
Balanced and lightened crank system,
ACL engine bearings,
Lightened flywheel,
N-group converted oil pump,
A-group Oil sump plate,
Magnecor spark cables,
Electric power steering pump,
Air intake system:
Polished and lightened throttle body,
GSG throttle adaptor,
Espace v6 airbox,
Itg filter,
A-group air intake,
Exhaust system:
Clio Maxi devill 4-2-1 collector,
55mm exhaust system with side pipe,
Sport catalyst ( at these moment out of car).
Fuel system:
Green high flow injection,
4.0 bar fuel pressure regulator,
Fuel Line in steel braid inside the car,
Ecu:
Remaped on dyno and road standard ecu,
New engine and interior loom.
Cooling system:
New engine cooler with Turboworks fan,
Samco cooling Pipes,
Mocal 16 row oil cooler,
Braided oil feed Line,
Gearbox:
JC5 Rebuild gearbox with 4.5 ratio,
Short shifter with aluminium 15 cm gear knob,
Front suspension:
Bilstein B8 coilovers,
Hr springs with Kw helpers,
Front reinforced wishbones,
Wishbone and Arb poliuretan bushes,
Standard or 25mm front stabilizer mounted on poliurethan or uniball.
Front negative on eibach spring and shock absorber on uniballs.
Rear suspension:
Bilstein B8 shocks,
Teflon bushes In rear beam,
Rear hubs from clio sport with adjustable angles.
Thicker rear beam rod.
Brakes:
285mm front discs (r21 turbo),
Reneved front calipers, with special adapters,
Ferrodo ds 2500 front pads,
Ferrodo ds 2000 rear pads,
Motul 5.1 brake fluid.
Steel braid brake lines,
Brake proportioning regulator,
Hydraulic handbrake.
BODY KIT:
Car painted in Renault sport colors,
Clio maxi Hood inlet,
A group roof inlet,
Speedline 15 inch Alloy wheels,
Sparco front and rear pins on boot and bonnet,
Front and rear bumper on pins.
Single front wiper,
Universal kit-car rear spoiler.
Interior:
Full rollcage,
Front and rear strut bar,
2 x Sparco junior approved bucket seat,
2 x Takata 6 point harness,
Battery inside the car in boot box,
Flocked dashboard,
RRS 350mm steering Wheel with snap-on adaptor,
Sport tachometer, oil pressure gauge and shiftlight.
Extra swithes panel with energy cut-off and voltmeter,
Carbon fiber footrest for driver and pilot,
Remove all unnecessary items.
Whole interior sprayed on white.
I start theese project in another clio body, but we make theese one from zero..
Old interior, now i make two seats.
I wait till end of winter and i make new photos. Cause many things was changed, but i don't make potos.
More pics are here:
http://czuczu.estrefa.pl/img/CLIO/index.html - old shell
http://czuczu.estrefa.pl/img/CLIO2/index.html - new shell
http://czuczu.estrefa.pl/img/CLIOSILNIK/index.html - engine rebuild
Thx, most things we make ourselfs and many parts we produce. in next few weeks i update all things when i put new parts
Quick update: my car on trailer
Some ride In short karting track
New aluminium strut bar, bought from celica for 3 pounds/
Package from England with Magnecor.
New end of Exhaust causa old one was too loud
Battery removed from passenger seat to end of car
New carbon legs cell
I change and relocate a handbrake rod
Almost ideal..
New clocks almost fitted
I cut rear bumber to free ait from down of car.
And i add some stop lights.
And for end i put standard lamps + Clio two eys blend + renault sport poli cover for lights.
Next update soon cause I prepare for first track in these year.
Absolutely amazing !! stunning. You have spent a lot of time making the ultimate clio.
Yes spoiler dosn't work as good as aluminium one, but i like 90's style. I make most thing myself so i know my car
Time for little update:
i put used toyo R1R, and new speedlines but no from williams.
I go on track and here some new onboards - only 3rd place in class:
i put new thermo bandage cause old one was in ruin.
New stri gauge was broken ( from USA so no guarantee) so i put 30y old Voltage from VDO, new oil temp gauge from vdo, and 15 y old oil pressure gauge from VDo with new sensor.
And finally i only wait for last package from italy with new short shifter. Should be much better than standard one on uniball, because here we have Spring like in CAI shifter.
Now misshift should be almost impossible.
I put new shifter and it really work wonderfull.
But dust from road and heat from exhaust was uncomfortable so i put a rubber from old polish car.
I also change screw from M4 to M5 in Canards.
And last thing, i remove all stickers, repaint some parts in car and I polished with machine whole bodywork.
And now car wait for trackday.. or new buyer.
Time 4 up:
Thicker car stabilizer:
25 mm aluminium distance between gear knob.
When I see the thickner sabilizer work, i make it much better.
And I add some orange sticker.
And i run in Classic auto Cup ( polish contest for youngtimers )
I drive bit too cloose.
Next day i went to another track day:
And my future plan:
Longer shafts, steering rods, and another steering rack.
And i change and weld gear rod.
Yes i still rebuild it. At theese moment we try to put r19 stearing gear to clio, but nobody know is it the same part in both cars..
  • Like
Reactions: Gus
Quick up. I wrap a fuel cup, and cut a front bumbper.
But most importand jobwas adding extra 10 cm on front axle
We cut it on laser.
Unfortunately man who was welded these parts, has got bad day
Finalcolor
Standard vs new ones.
On car.
Now i wait for maxi front fenders to paint them.
I also sent for regeneration standard steering gear. And new hydraulic lines.
New brake lines.
And now it's time to rear beam and fenders
Time for up. We finish the paintjob.
New vw fuel tank cap.
And we finish front and rear suspension.
Some new stickers.
I cleaned the air filter.
And we went to the trackday.
Some photos.
Unfortunately new rear bearing broke up.
And i crash...
But I make a new parts
Finally I almost fix-it.
Time 4 up. I put slicks on rims.
Front bumber on his place.
We put new stickers, fix all problems and went to trackday.
666666666666666666666666666666666666666666666666666666666666666666666666666666666.jpg
38 degress on plus, wchich make lot of problems.
6666666666666666666666666666666666666666666666666666666666666666666666666666666666.jpg
But fun was greatfull.
66666666666666666666666666666666666666666666666666666666666666666666666666666666666.jpg
More photos from track.
666666666666666666666666666666666666666666666666666666666666666666666666666666666666.jpg
6666666666666666666666666666666666666666666666666666666666666666666666666666666666666.jpg
66666666666666666666666666666666666666666666666666666666666666666666666666666666666666.jpg
some onboard But gopro also quit... from his job.
When I back to garage i change some parts.
And send injectors to the Service.
And I port the throttle body.
Now it work much better.
But rear wings need some support.
New 60mm exhaust system onboard
A whole system in 60mm diameter, v-clamp, and silencers build of stainless steel.
And some work with underpressure of engine.
Another update.
New cooler holes.
New air fed.
New GoPro mount.
And some pic's from track ( with slow bmw )
Fastest onboard.
After the track i made a new computer mount.
Old speedometer cable.
And I made a new air intake from the resin.
I adjusted the convergence of the rear wheels
New exhaust heat shield
And i change the brakes from 285 to standard 259 discs, standard yokes, etc.
Almost new Hankook Wet's and slicks.
And first set of Intra wheels. ( from Honda )
And a second one.
...painted by me. And wheels on car.
I screwed up the new tow hook attachment \.
And last ride these year.
And that's all. Now i wait for new gearbox with 4.9 main ratio.
lol, mega, the only car that needed 17" wheels and no, crazy man goes other way and smaller instead!
awesome project, keep it going!
