Clio 172
Howdy all, have myself a clip 172, is lowered a bit and I've just had the timing belt done.
Whenever the car is travelling straight at sub 20kmh and you foot it, it seems as if there's a vibration like a stuffed tie rod or unbalanced wheel, and goes away above 40kmh and doesn't return, it seems to get worse whenever you book a right turn but doesn't happen when cornering hard left.
Now I did run my offside driveshaft with little grease as a boot split about 40km from home on the freeway but that's all fixed up and there's no play
Could it be the engine is pushed too far to the left and causing a slight vibration? It needs new mounts but has a powerflex dogbone. Also, is the nearside driveshaft cup in the diff not that hard to replace either? Cheers
