Seems to me like a brilliant idea that's been let down by strange regs...
next race is at donnington park on the 21st and 22nd of September more than happy to run through any questions you have.You say it's its been designed around driver development, but then you have an instructor interested in taking part ? Does this not go against what you are trying to achieve. Put the dates up, and I'll try and come along for a chat.
The regs are spot on when they are explained in full then you start to understand the reason to why the club have put them in.Seems to me like a brilliant idea that's been let down by strange regs...
Quick question, if I do a few races in 750 then decide I want to go onto a more freely regulated series such as Tin Tops can the ECU be unlocked to allow ITBs, Cams ect and mapping or will I have to buy another one from K-tec?
Also dates, I want to pop along
Just seen date of the race Ill email closer the time
Donnington park 21st and 22nd SeptemberDates??
Basically the clio 182 is the best one if all clios are allowed to enter, people will just change hubs and shafts manifold and use the larger port head then we have different engine combinations with different power gains ! How is that fair when others don't have the money to spend to compete !
Using one clio ie the cb22 make sure we all use the same engine combination and run the same power hence a level playing field.
Price wise clio 182 are available if you spend the time looking for as little as £900.
the ecu is no way an over kill it allows the club to stop cheats with use of data logging and we can swap ecu,s from car to car.
Huge gains can be made from mapping as you can map all the engine mods to it I.e lower compression changes and valve timing and air flow modifications thus giving a increased power. The k tec ecu stops all that
ps immobiliser can't be removed due to the can bus link inside the ecu trust me I've spent 9 months last year trying to get around it. Early 172's can have immobiliser removed for around £60 but not the later ones !
Someone really has been sucked into the propaganda!
The 182 has the smallest exhaust ports.
Big gains really aren't to be had by remapping.
Valve timing can still be altered without touching the ecu.
As for the same power/playing field. If you speak to anyone who's not out to sell you a product, you'll be told that the 172/182's vary in power massively. I.e 160-185.
The immobiliser can easily be removed if you know what to do.
Without starting a row as i'm not out for that, the 172 cup is way better than the 182 CB22 mainly due to the lack of ABS
what's to stop me bolting a large port head onto a 172/182 bottom end? Without pulling the exhaust manifold off no one will ever know! (using the 182 rocker cover)
you can't check engine numbers because theyre unreadable due to rust
and you can remove the immobiliser, i've done it on a FBW car, little box of tricks, £60 done!
Genuinely interested, who pays for the new cambelt kit thats required once the old ones being untensioned to remove and check the internals?You could yes and put on big valve head but when it's sealed and rechecked at later date you would have you points taken away !
Plus the club strip engines at random times so you wouldn't get away with it
^ £300 a race though isn't it?
£300 for two 15 minute races and a 15-20 minute qualifying session.
and the head set and bolts.....
and who does the work?
As per all championships the driver is responsible unfortunatly, hopefully this wouldn't happen to often due to the high spec ecu we run !Genuinely interested, who pays for the new cambelt kit thats required once the old ones being untensioned to remove and check the internals?
Is there some kind of hidden joke in this sentence?hopefully this wouldn't happen to often due to the high spec ecu we run !
