Rob
		I haven't come across one black soul gem
I seem to not be very good at this game.
Time to level up enchanting then...
I have a staff that fires super heated fireballs, and a Jabaowoky thing (don't know the actual name). They both require soul gems to keep them fuelled up, but most of my soul gems are empty. HTF do I charge them up?
This enchanting business. How does that work? Seems very confusing, much like the whole ammo thing in FNV.
Can you enchant anything weapon wise?
You first need to learn the enchantment by disenchanting a current item you have. You then use an Enchanting table to put that enchantment into another weapon or item of clothing/jewellery. To do this you also need a full soul gem. The larger the soul gem, the more effective the enchantment will be. For example, I had a circlet with 15% bow damage. As I don't want to wear that crown, I disenchanted the item and then used the enchantment (15% damage with bows) on a normal jewellery ring. I used a black soul gem (the biggest) and this retained the 15%. If I'd used a smaller gem the % would have decreased accordingly. So using a petty soul gem I'd have probably only got 2% damage instead of the 15%.
There's a decent guide online somewhere.
Sigh. Broken quests. I love this game but I am losing faith in it. Fast.
Cheers, will try that later. So is for example a war hammer of frost an enchanted item? So I could disenchant it and enchant a sword if I had a soul gem? Can you use multiple gems as the ones I have so far are pikey ones.
I've had one broken quest in 130 hours of play on 360. It fixed itself after a quick reload anyway.
Mind you, it is coded for 360 so there you go.
Started a new character to build up into an assassin. Going to finish the main quest line again with him to build some levels then tackle the Dark Brotherhood. I destroyed them all with my thief character; he topped out at Lv51 yesterday.
Currently Lv9 with this new fella.
You're either very unlucky, or steam hates you.
No problems here. Scutch, after you lined the lights up did you attack that cocky tw*t face??? I did.
Just completed the college quest, well the first bit, pretty cool. I need that fancy staff you have though.
I killed a rabbit
Sanguine's Rose. It's an awesome staff.
Also, I didn't butch that mage guy, even though I was tempted. I just took a deep breath in and left. Only to find Ancano being a tw*t. No change there then.
You can summon Demora whatever? How?
Oh and when you get conjuration high enough, double potency and 3x duration makes them pretty decent. I pretty much use my frost atronach as a meat shield and a my flame atronach as a second archer type thing... (surprisingly good shot against dragons etc)
