Poweys artic bloo 182
  106 GTI
Decided id start a progress thread instead of cluttering CS with multiple threads, also easier if anyone wants to check my progress.
Heres the car when I first picked it up, Had both cup packs and only 30k on it.
From day 1 I didnt want the car to stay standard so a 3/4 plate from fancyplates was ordered, also some silvervisions as I hate the eggs.
A month later I received my miltek and decat
This was booked in at prospeed to be fitted and the centre silencer removed.
Some weight had to be shed so the parcel shelf, rear bench,inner boot plastic, under bonnet sound deadening and engine cover had to go
Fancied going a bit wild so out came the mercedes telecom green
I then decided to do a cut down version of the standard tow-eye
Had a bit of pipe left over in work so decided to make a strut brace on the cheap
The splitter had seen better days so I opted for the whaledick megan one.
I was then able to source a second hand set of GAZ coilovers, which I picked up and fitted the same day. These pics was then taken a few days later
It then went to birchdown for a cambelt, aux belt and match inlets to be fitted ( courtesy of codgey )
Also the pfte gaskets accompanied the inlets
I then got bored of the green badges and sold them on to davesport172
In place went some amphasite ones.
Also bought a spare set of bullets and painted them like this
I quite like the cheeky stickers and after attending the pistonheads show I went for this
My AST topmounts arrived so I fitted these only to find they need machining to fit my 57mm I.D GAZ springs
Soon to go on order is some shorter falkner springs for the front.
The fogs were then ditched... ( to be continued )
Another cheap mod thanks to the forum was the carbon bonnet from Josie172cup
Here you can see another cheeky sticker which is a bit of fun between a few friends
I am now in the middle of relocating the battery ready for a cup racer style induction setup, a cold air feed will be run from the fog.
I managed to nab a bargain GRP box off ebay to put the battery in
The acoustic valve has also been removed
This is the 0 awg for the battery relocation
Heres some seats I picked up yesterday from ebay which have some omp 4 point harnesses also
Now on the big save to get some rails for the seats and the resistors.
I need to double check the measurements on my arb to make sure my powerflex ones are the right size.
Also fitted an alpine x001 courtesy of mt audio on here, will get pics of that again though
2 new toyos also sat in the living room ready to be fitted on the front
Once the induction setup is done I will use my rstuner to remap it
  Porsche Boxster987S
mint!!! Love it mate. Whats the benifits of the ast topmounts and how much?
  106 GTI
well worth the money
camber and castor adjustability, increases turn in responce and takes most of the clonks away from the front end
  106 GTI
£150 ish?
You have GAZ too dont you? youl need them machining different to other coilovers due to the springs being a smaller inside diameter
Coby.
  XC60-R.......V40-R
Looks Great.... I was always curious how a CF Bonnet would look on Arctic and it looks great :)
  106 GTI
UPDATE
Recaro rails on order
My 450lb faulkner springs have arrived from tweeks
Started and nearly finished the battery to the boot relocation tonight
Left to do; drill and bolt the GRP box to the floor
Drill and bolt the lid shut
Decide on a final position for the filter
  clio 1.2 16v
thats a brilliant job on it mate. the carbon bonnet looks the smart as wi the blue n the splitter in carbon aswel. hope to see more piks soon :)
  106 GTI
Managed to bag a bargain wheel on ebay for £50 brand new, momo something
wasnt fussed on the bling bling look so out came the rattle can
Had a visitor to
Boss kit should be coming from ktec anytime soon
Recaro rails have turned up so hopefully get the seats in, decided on getting the airbags turned off on a clip machine so need to sort that.
Wheel studs have arrived along with something fancy from america, il let the pics do the talking when fitted
Hixle
Hi Kiss Luke E****
  E90 M3
^Decat?
I'll get my coat...
Car's looking great fella!
